New Layout Knife
Started by Rooster, March 24, 2014, 01:32:01 AM
Rooster
I like to use a knife for doing my layout on beams and for marking lumber for sawing... I seldom use a pencil.  I have used many different folding and fixed blade knives, but I wanted to design something different for a couple of up-coming projects.  And since I really only use the tip of the knife, I didn't need to have very large blade.  (Disclaimer: I am not a blacksmith, or a bladesmith, I just like to design and make custom tools to use on the job.)
I started by putting my ideas into drawing form and then adjusted the design as progressive versions.
I used an old 10"table saw blade and cut out the profile.
I used some walnut for the handle.  It is patterned after a palm awl and made to fit inside the user's hand.  Some brass pins and epoxy...then on to the belt-sander...finished sanding by hand and some oil...and it's ready to go to work...
Peace, Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Jim_Rogers
Looks great, how does it work for you?
Jim Rogers
Rooster
It feels really nice in the hand...I was shooting for ergonomic to help with comfort and control...it's also sharp, and easily re-sharpened since there is only 3/4" of blade edge to mess with...it can be used right or left handed, and can be stuck into a work piece and made to stand up straight.  I'm using an older utility knife sheath, but I hope to make something more custom and secure...maybe have a safety snapped strap when I'm not actively using it and walking around the job-site or shop...I don't want to have it fall out and lose it in the mud...
The ironic part is that it's made from a saw blade and a piece of sawn lumber...but designed and used to mark lumber, to be sawn...
Mike Rowe
                          Rooster
giant splinter
Rooster,
That looks like a well engineered layout knife for sure and good use of an old sawblade, nice work and I bet its doing a good job for you.
roll with it
Brad_bb
The handle is Walnut, no?  How do the brass pins hold the handle on?
Brian_Weekley
Rooster, great job on that homemade prison weapon, er, ah, I mean timber frame marking tool...  ;)  Seriously, nice looking.
e aho laula
Rooster
Quote from: Brad_bb on March 24, 2014, 10:53:43 AM
The brass pins help align all the pieces when they are sandwiched together...epoxy is used to laminate the layers...the pins are a backup if it de-laminates...
Thanks for the feedback...
Rooster
Mike Rowe
                          Rooster
Brad_bb
Yeah, Rooster is covered if he ends up in prison (wrongly convicted of course).
classicadirondack
What  did you use to cut the steel?
Rooster
Quote from: classicadirondack on March 25, 2014, 06:52:57 AM
I used a cutting wheel on a 4" hand held grinder to rough out the shape, then a grinding disk and a flap wheel sanding disk to shape it to size. Total time to cut out the shape: 6 min.
Mike Rowe
                          Rooster
sawmilllawyer
Really nice work there Rooster.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
addicted
Great knife Rooster
Your handle looks a lot like a some carving handles. Have you found that shorter, stocky shape to be comfortable?
Rusty
Rooster
Quote from: addicted on March 27, 2014, 09:18:36 AM
Great knife Rooster
Rusty
Yes, it feels very comfortable like a carving tool...the only thing that I would change so far is shortening the distance from the tip of my index finger to the tip of the knife...the longer that distance, the harder it is to zero in on a particular mark on my tape when marking for length...but other than that it's now my go-to tool...it also double as a utility knife and conversation piece...
Mike Rowe
                          Rooster
RavensWood
Looks great Rooster. Just curious - is the cutting edge a single bevel or a double bevel? Most striking knives are a single bevel, utility knives are double. I use both but for laying out joints I tend to reach for the utility knife - not sure why. When I am making furniture I almost always use the single bevel knife.
Rooster
As of this posting, I have it as a double bevel...but I want to re-sharpen it to a single and see if I like it more or less.  I'm right handed...any suggestion on which way I should bevel?..Flat side to the left/bevel on the right?...or the other way around?
Thanks,
Rooster
Mike Rowe
                          Rooster
RavensWood
Definitely bevel to the right. The idea is to produce a right angle cut against the guide - which you would be holding with your left hand. Double or single - I'm not sure whether it really matters - depends on what you get used to. If you hold a double bevel knife at an angle you still end up with a right angle cut against the guide. With furniture making you are sometimes following a piece thicker than a ruler and the right angle blade then does a better job. As a side note - I 've always enjoyed your postings and you have sort of inspired me to try to join the group rather than just stand back and listen (and the same comment about inspiration goes out to all of the people that post here regularly).
Rooster
Quote from: RavensWood on March 28, 2014, 10:27:02 PM
I just clicked on the "like" button...
Thanks RavensWood!
Peace,
Rooster
Mike Rowe
                          Rooster
razor
Fine looking tool for sure. You've inspired me to make my own.
How did the bending of the steel go? No issues with cracking?
Rooster
Quote from: razor on March 29, 2014, 08:11:37 AM
I wanted to use my forge to heat up the steel, but I decided to use the bed of coals in the wood-stove...it glowed yellow, and then I used a wide mouth visegrip and a linesman pliers to bend over the tab.  After I finished grinding it to shape I heated it up again to quench, then it spent 4 hours at 600 deg. in the oven.  Cleaned it up and was ready for the handle, which was pinned and epoxyed together...
Mike Rowe
                          Rooster
