Pump Rotation
Started by Ivan49, March 23, 2014, 12:36:05 AM
Ivan49
 I am getting old and have not messed with motor and pumps in a long time. What is the rotation direction needed on a hyd pump to have a direct hookup to the motor? When you check the pump rotation is it determined by looking at the shaft end of the pump or from the end oppsite of the shaft. Thanks Ivan
blackfoot griz
Usually called from looking at the shaft. If the engine/motor turns CCW, the pump you need should be CW.
