Looking to buy a cheap chainsaw.
Started by AnthonyLordi, March 18, 2014, 08:22:06 PM
trapper
I asked about the echo cs310 in the chain saw area.  Look it up.  Seems like the best buy in a small saw.  That is what I plan to buy when my poulan dies.
CTYank
Quote from: AnthonyLordi on March 18, 2014, 09:28:02 PM
Quote from: Hilltop366 on March 18, 2014, 09:21:10 PM
Welcome AnthonyLordi, I don't have any experience with any of the saws you listed but I can add one, my brother has had good luck with his Husqvarna 435, he has cut enough wood to heat his house for two years now with no problems. lots of good reports for Echo as well. Dealer service and location should be a factor for making a decision.
That model exceeds my budget a bit, I appreciate it though.
There are a few service centers nearby, and there are a few dealer only places locally also, I must say I'm pretty capable of repairs myself on most other tools or appliances, so should that really matter?
Thank you.
See how your budget works at VMInnovations dot com, for a 435.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
Husqy 576XP-AT
Mix of mauls
Morso 7110
Oliver1655
Word of caution when tightening the bar nuts on a saws with the studs mounted in plastic like the Poulan Pro series.  You only need to snug them tight.  If you try to get them really tight you will pull the studs causing the plastic to bulge & the bar will not tighten at all.  There is a reason the scrench included with saws have a short handle/screwdriver.
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
