Cheap file holders
Started by Yatt, March 11, 2014, 05:53:02 PM
Yatt
I heard about this and gave it a try. Works great.
Just drill a hole in a golf ball that is slightly smaller than the file and pound on. They fit into the palm of your hand better than the plastic file handles.
Since I am a golfer and pick up about 2 five gallon pails a season, I should have a good supply.
288 XP Lite
372XPG
562XP
357XP
550XPG
346XP
Dolmar 7900
028 Super totally rebuilt and ported
Speeco 28ton splitter
Silvey 510, Oregon 511AX & Tecomec grinder
M_S_S
Horseshoers have been using them for years on their rasps, at least out here on the left coast. Ed
2- 562xp 24"bar
         576xp 28"bar
         385xp 28" and 32" bars
         25 ton Speeco
         6600 Ford
         02 Dodge diesel
         73 Ford 250
LeeB
I got more scrap wood than I will ever run out of to make file handles out of. Don't have too many golf balls, although they show up every now and then from all over the 200 acres from when the boy played golf in school.
I was going to say, I have enough handle wood for 20 men. :D
7sleeper
I reuse the ones I have... When a file is dead I take off the old grip and put it on the new file. This has stood, for me, the test of time...
;D
7
petefrom bearswamp
I make mine out of 1" square stock with a small hole drilled for the file.
This way I can rotate 1/4 turn every tooth which I think helps file life.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
LeeB
Some of mine are square, some rectangular,and some round. Depends on what's handy. I've even been known to use a small piece of branch.
7sleeper
Quote from: petefrom bearswamp on March 12, 2014, 10:08:39 AM
I always rotate after every stroke.
7
I use a file guide on the brush blades, so I rotate every blade. :D ;)
Philbert
Too many pun opportunities here: Do they fit to a 'T'? 'Wood' you recommend them for a guy who 'putters' in his shop?  How do you 'drive' them on? On par with commercial handles?  How do you make a hole in one?
I like the round handle distributing the force over a wider area than the sharp file tang.  But I use a long, conventional file handle, with an extended finger, to help control the angles of the file.  Not sure that a golf ball would give me this type of control.
Philbert
DaleK
I thought this was what broken hockey sticks are for?
Hud-Son Oscar 330
Wallenstein FX110
Echo chainsaws and a whole bunch of tractors
