Can i run a husky bar on my 925 homelite
Started by husky2100, March 10, 2014, 10:15:45 PM
husky2100
Will a husky bar fit on my super xl 925 and will it oil properly?
webgal
Looks like the groove on the Husky bar is 9mm, whilst the Homelite is reported to be 9.5. Perhaps someone may know how to mod it enough to have things fit and oil. Otherwise a good bar mount is D196 (Oregon fitment code number).
Gotta know when to fell em, know when to tell em, know when to walk away, know when to run....
mburrow
if you have the bar and the super xl 925 try it, if it fits over the mount bolts check to make sure the oil hole lines with the saws oil port.
I have used my super xl 925 bar on a husky 394 and it worked fine, but I can not say the other way around as the bar on the 394 was off a craftsman-poulan 5200 and it did work on both saws
Grandedog
     Howdy,
   To fit the Husqvarna mount to the Homelite, file the bar slot out to 3/8". Then file the adjuster holes from round to square. Keep in mind that your drive link count will switch to what the Husqvarna bar requires.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
SawTroll
Quote from: Grandedog on March 11, 2014, 01:32:52 PM
     Howdy,
Regards
Gregg
Yes, and both mounts have what Oregon Calls the "D" tail, so the oiler holes will add up.
I don't really know how much the adjester holes really need to be changed.
Information collector.
Grandedog
     Howdy,
   The adjuster pin on the 925 is rectangular, so the round adjuster hole in the Husqvarna bar needs to be squared.
Regards
Gregg
Gregg Grande
JT78
I actually have done this I run a 24 from my 395 on my homelite 925 had to use a flat file to open up the slot for the studs but everthing else worked fine with no other  changes.
Grandedog
Quote from: JT78 on March 11, 2014, 07:13:32 PM
Howdy,
For future reference, do you remember if your adjuster pin is square, or rectangular shaped?
Regards
Gregg
Gregg Grande
JT78
It was square but all I JD to do was run a round file through a couple times to make the hole just a little bigger and it worked.
Grandedog
Howdy,
Thanks for information.
Regards
Gregg
Gregg Grande
