Gauges on the dash of my 230tj. What are they?
Started by riverlogger, February 18, 2014, 09:58:10 PM
riverlogger
I started my 230 for the first time today at dusk and just noticed that there are 2 separate psi gauges on the dash. One is on the lower row of the dash that has an almost all red background with a small sliver of blue about 3/4 away across the gauge. It has two separate reading charts with kpa being one of them. The one on the top has a blue background and is just in psi and I believe it is the engine oil psi gauge. The thing is they both rise and fall with the engine rpm which leads me to the question what is the spare gauge for assuming only the blue background on the top is the engine psi gauge. Thanks in advance for any and all help
David-L
No clue, You have to follow it to it's source. Electrical connection, or some other. maybe something to do with the tranny, never had an automatic before.
                                      David l
kiko
The lower gauge is transmission pump pressure it should run in the blue . Around 270 psi if I remember correctly.
