Norwood LM2000 part
Started by sawwood, February 11, 2014, 09:46:48 PM
sawwood
Any FF member that has a Norwood LM2000 I need the part number if there is one
for the adjustment guide arm ? The one on the 2000 looks like it angles about 10 degs
to the left. We have a Mark4 mill and the arm is straight down to the guide roller. I
think if we had the one that's angle we could get wider cuts. Ours will cut a 16" cut
and would like to make 18 or 20" cuts. Pm me if you have a part number or a copy
of the parts list. I have email Norwood about it but haven't heard back.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
chet
the manual only refers to it as "adjustable blade guide arm, item 102"
papow22
 item  102    1 Adjustable blade guide arm    part number = 2K-ABGA-003
GET A DATE WHEN IT MADE ALSO WHO WAS THE ORIGINAL OWNER.CAUSE THEY WILL NOT SELL YOU A PART WITHOUT ALL THE INFORMATION.FORGOT TO SAY SERIAL NUMBER ALSO.YOU CAN GET MORE INFO FROM OWNERS ON THE NORWOODS FORUM.
            Portable sawmills | Norwood Industries. ;)
Lives to do sawdust,run a trapline,hunt big game,live life to it's most.Got 4 mills a circle mill,(2 band sawmills) Norwood's 2000, Trim Saw,Beam Machine (chainsaw mill).
papow22
Also forgot to mention max log diameter = 31 inches
max  Bord Width  =   24 inches
sawwood
Thanks guys for the info. JR is the owner of the mark4 so he has all the info needed to order parts.
Sawwood
18" planer/molder
