it wont turn
Started by coxy, February 06, 2014, 08:27:46 PM
coxy
ok a friend of mine was going up a hill and miss shifted went down the hill backwards with no brakes hit the left side in a tree half turned now it wont turn ether  way but if you rock the skidder back and forth it will turn some what but have to rock it the rams are not bent I think its in the steering valve maybe popped a o ring or the spring   any help would be great :) :)
Coon
What model and year of a machine is it? More info needed to make an educated guess.
coxy
Maine logger88
Do you have a gauge to check the pressure that could tell you if it is the valve?
mad murdock
Sounds like maybe when it hit the tree something could have gotten fouled up with the steering valve (hydraulics) maybe pressure was forced against pump flow and a check valve is jimmied or something?  A puzzler for sure!
coxy
little more info for ya it is a 1 line pressure pump  and the blade moves up-down fine it is just the steering  and some times the control spool sticks like a oring or maybe the spring is binding it ???  I never had or seen this happen to any one before
logman81
Ya seems to me it's something in the valve bank , if the lever centers when letting go of it it's probably not the spring.
Precision Firewood & Logging
UN Hooker
Sounds like it might have popped a piston off of a rod - (broke the end off the rod inside the cylinder).
               UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
coxy
took the spool out all the orings look good took the fitting out of valve nothing was there going to try and hook the blade valve up to steering rams to see if it works if it does then the steering valve is bad wright? what do you look for then? if it don't work then will have to pull steering rams out and take a look see thank for the help  :)
riverlogger
coxy is it a dual cylinder steering setup? It sounds like one of the rams has broken at the packing end thereby making it impossible for the other cylinder to overcome the weight of the machine (unless you are rocking it back and forth) and the fluid that's bypassing in the failed cylinder. I have seen this happen before in a 666d model clark.
coxy
Quote from: riverlogger on February 07, 2014, 10:15:59 PM
yes it is dual pistons
barbender
I think his real problem is with his brakes ::)
coxy
Quote from: barbender on February 07, 2014, 11:27:50 PM
have you ever lost the brakes on anything its not fun
David-L
UnHooker has my vote. lost all movement on the close and open on my grapple once , the piston on this European model screwed on the end of the rod and had come off. Drilled,tapped a set screw in and that won't happen again maybe. It's in the steering cylinder.
                                      David l
coxy
that's what I have been saying to my self   but have been procrastinating taking them off there a pain in the    to get to  :D :D thanks for all the info
logman81
If it's the machine that I sold all you will need to do is remove the floor pan and they are easy to get to. It would easy to put brakes in it.
treeslayer2003
on a two cylinder steering system you can plug the lines on the bad one and get out of the woods with the one good cylinder. ;)
coxy
Quote from: logman81 on February 08, 2014, 08:56:50 AM
ya its the one the e brake did work till this happened  ;D pulled the handle so hard it snapped the end off :o if we had some hard ware to go with it wouldn't be hard but as soon as warmer weather comes going to bring it to my shop and make some thing work ;D the prob is that its cranked all the way to one side on a bank that's what making it a pain in butt
coxy
Quote from: treeslayer2003 on February 08, 2014, 10:08:34 AM
tried that wont work at least on this thing any way ;D
lumberjack48
If it has a control lever for hwy use, check it to make sure its not released all the way from the jar.
1270d
Does that lever slow the steering for higher speed driving?
logman81
Lumberjack this is the skidder that I used to have, it doesn't have the lever you speak of.
coxy
up date found the prob the piston broke off even with the nut that holds the packing there is about a1/6 of a inch of threads left so need new piston         thanks guys for all the pointers and the help learnt a few new tricks on the way    again thanks to all
barbender
Quote from: coxy on February 08, 2014, 05:58:39 AM
The first skidder I ran didn't have any brakes, it was all flat ground so it didn't matter too much then, but I knew it would catch up with me eventually if I kept running it. The skidder I bought (Pettibone 501) has brakes, I have to fix the Parking brake though. I wasn't trying too be too much of a smart aleck with my comment, I just want to make a point that many of us play with fire running the old cable machines with no brakes, this could have ended worse than just a broken hydraulic cylinder.
redprospector
Quote from: barbender on February 08, 2014, 11:48:50 PM
This is way too true.
