John Deere 540G-Transmission??
Started by JDeere, January 26, 2014, 05:11:07 PM
JDeere
One of the skidders on our job has a strange issue and I am wondering if anyone has experienced it or has any idea what it could be. That is, on very cold days after starting and warming up it will not go forward or reverse. You move the shifter into the different gears and it doesn't move. Sometimes after it warms (maybe hours) it will go. In warm weather there are no problems. All the other hydraulic functions work fine. Any help would be appreciated.
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
treeslayer2003
could it be the cables are stiff in the cold and it not really moving the valve?
just a shot in the dark here.
Nemologger
Have you tried a new transmission filter? I had the same problem and finally after 2 filters it is ok.Guess it had moisture in it and would freeze, but when it was warm it would flow.
Clean and Sober
JDeere
Quote from: treeslayer2003 on January 26, 2014, 05:27:58 PM
We are going to replace that this week if we can get it to move.
Quote from: Nemologger on January 26, 2014, 07:10:19 PM
Which filter was it, the screw on filter or the metal screen filter? Thanks for the responses.
coxy
not shur if jd has it or not but on the cat there is a screen filter in the bottom of the tranny it will get goo in it and do the same thing         good luck
Nemologger
the one I replaced was the spin-on you can see looking in where the machine bends, good luck
Clean and Sober
