Blade coatings?
Started by Robert Duval, January 26, 2014, 12:29:04 PM
Robert Duval
Hey all been a while. We have started sharpening all of our blades in house and it has been going well except for one thing, we are getting a thin buildup of sawdust on the blades casusing some serious drag. Does anyone know what the sharpening shops use to coat the blades?
The thin buildup I presume, is when sawing logs... not during the sharpening of the blades in-house.
What are you using for pitch build-up while sawing?
Chuck White
When I get done sharpening my blades, I take a rag with ATF and give the entire blade a good coating before I put them in the box!
Nomad
     What beenthere said; are you using lube while you're cutting?  Whatever the shop puts on the blade won't last very long.  The place I use for my Lucas blades just uses a light coat of machine oil on everything, bands included.  It's only purpose is to prevent rust while the blade is in storage.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Red Good
Has anyone tried cryogenics for band longevity ?
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
POSTON WIDEHEAD
Quote from: Red Good on January 26, 2014, 06:45:57 PM
No, but I've tried a metal detector.  ;D
Petroleum applied with a wick, nip the problem before it starts. If you have a buildup remove it wile the band is still on the mill. Frank C.
drobertson
A wick of diesel, a flood of coolant, or a knife to knock off the build up before removing the band, whatever is used should be used prior to removing the band if the issue is persistent.  This makes re-grinding much easier. A Brass brush is pretty handy when needed,    david
backwoods sawyer
I wipe them down with a heavy coat of deisel and oil, let them soak a while, later wipe off with a dry towle, that cleans them up before sharpening.
Backwoods Custom Milling Inc.
Jemclimber
Quote from: POSTONLT40HD on January 26, 2014, 08:04:27 PM
:D  :D  :D     That really had me laughing!!!    :D  :D  :D
lt15
Robert Duval
Sorry should have been a little more specific. This problem is happening on our gang saw and table saw. Our gangsaw is a woodmaster 718 and can not have water run in it. Our band blades still go to woodmizer to be sharpened.
Then sounds like your sharpening technique is causing the cutting pattern (kerf) to be too narrow and sawdust is getting down along the surface of the circular blade.  Possibly may be a result of too many teeth in the blade as well, making very fine sawdust.
Did this happen when the blades were new?
And to be clear, you are asking if there is a blade coating that you can apply to stop the sawdust buildup?
Bob I wonder if a clear spray wax would help.??  Frank C.
Robert Duval
No it doesnt happen with new blades and these are the ripping blades we got right from woodmaster.  We were sending them out to be sharpend and when they came back they would have this weird oily coating on them. The first thing I did was call woodmaster and they gave me the specs for minimum side clearances.  We are well above the minimum kerf limit. The sawdust builds up on the sides of the blades and creates so much drag that we can only run at half the speed we used to.
Chuck White
My suggestion would be to leave the coating (from the sharpening service) on the blades until they're ready to use.
When you need to change the blade and put one on that's been resharpened, just wipe it down with some diesel on a rag!
dboyt
Might try silicon spray.  I use it on sliding parts and NOTHING sticks to it.  I've never tried it on a blade, but haven't had your problem, either.  Another thing that will clean up a blade in a hurry is to run it through some eastern red cedar.
Nomad
Quote from: dboyt on January 29, 2014, 10:00:26 AM
     I'd be real leery of silicon spray.  I tried that once.  Nothing sticks to it, but the Dang blade won't stay on the wheels either!
Lucas DSM23-19
QuoteSorry should have been a little more specific. This problem is happening on our gang saw and table saw. Our gangsaw is a woodmaster 718 and can not have water run in it. Our band blades still go to woodmizer to be sharpened.
Just a reminder, that the OP was talking circular blades, not band blades. ;)  ;)
Nomad
Quote from: beenthere on January 29, 2014, 11:52:36 AM
     Uh, yeah...  That does make a bit of a difference. ::)
Lucas DSM23-19
Peter Drouin
Is the wood green or dry?
A&P saw Mill LLC.
License NH softwood grader.
drobertson
I have seen this on table saws before, side clearance on the tooth is worth looking at.  Sharp teeth will help but not alleviate this totally.  It has to be wood type specific in conjunction with blade sharpness and feed speed.  A brass brush would help knocking off the build up without affecting the sharpness, as to a coating,  try a kerosene wipe between cuts.      david
Robert Duval
All the wood we cut is green. We cut 1 inch boards with the mill then stack them up for a couple weeks. Then they make it to the woodmaster.  When we first got the woodmaster we were feeding boards through it at a rate of 16 feet per minute. I called woodmaster and they said the same thing about the kerf. I measured the teeth where they asked me to and they said we were with in spec. That's when they recommended a blade coating. When I asked what type he said to call a sharpening service, tried they wouldn't tell me what they use.
Peter Drouin
I think it's the set, but I would get a new blade  and one you sharpen side by side and look to see what is different.
Just because it's in spec don't mean nothing. good luck
A&P saw Mill LLC.
Robert Duval
That sounds like a good idea. We are almost to the point where we need to cycle in a new set of blades anyways.  Will measure up the new ones and the old side by side.
Robert Duval
How important is the relief cut on the back side of the tips? My dad hasn't touched them at all and it doesn't look like the sharpening shop did either, could this cause this issue?
