Keeping the critters warm.
Started by Qweaver, January 24, 2014, 07:06:31 PM
Qweaver
I put 60 w Al shielded lamps in the chicken coop today.  That was the highest watt that I could buy at the grocery store.  The coops are small, about 2'x2'  cross section.  I hope this helps.  I think they will huddle in there.  I hate to see animals suffer in the cold...but Sarah will not bring them in the house.  :D
Feed them good and no drafts. But the lamp will help too. I put a light inside when I was plugging holes. I would make sure they had food all the time when it was cold. When we had goats and horses, I would double the grain.
clww
I saw a big selection of heat lamps last weekend when we were in Tractor Supply.
Many Stihl Saws-16"-60"
18-Wheeler Driver
Peter Drouin
I put an electric heater in the coop, stays + 38  ;D
It's hanging from a wire and 1 time a week I blow it out with air [dust you know] :D :D :D :D :D :D
A&P saw Mill LLC.
License NH softwood grader.
Barebuttminer
You do know that birds don't sleep when the lights are on don't you. You might try covering the lights with something, I'm thinking tin foil or maybe a soup can, to block the light and still allow the heat to pass though.
Wood-Mizer LT15, John Deer 450C Dozer, Husqvarna 455 Rancher, Stihl 009
Qweaver
Quote from: Barebuttminer on January 24, 2014, 09:44:44 PM
I tried to research this and got mixed results.  My cousin has been heating and lighting his coop for months and his chickens seem to be sleeping fine.    I did turn my lights with open face down so that the light is mostly blocked.
gspren
Quote from: thecfarm on January 24, 2014, 07:10:48 PM
  We had goats and a donkey for many years and still have the donkey and I read not to increase the grain because it's a short burst of heat but to supply plenty of good hay and water, the moist hay in their belly gives better longer lasting heat. The dog has access to my "man cave" shed that is kept at about 60 F.
gspren,Never heard of that. We fed them morning and night. All the hay they wanted. There was hay in the crib all the time.
