john deere 440a radiator
Started by duckslayingpro, January 20, 2014, 04:16:03 PM
duckslayingpro
My ole skidder been getting warm on me. I replaced the water pump and thermostat at the end of summer help a little but not much. Well today the outside temp was about 55 and it started getting warm again. Its been fine all winter. Ive cleaned between the fins of the raditor but hasnt been much help. The fan has got in the fins and bent some. Can a good raditor shop repair the fins and maybe recore the radiator or would i be better off try to find a good at the skidder junkyard?
Thanks in advance.
Ed_K
Try to find a used one. I had mine re-cored was close to $1100.using my upper and lower tanks soddered on  :o .
Ed K
Firewoodjoe
Sure it's flowing well?  We put dish washer machine soap in it and run it for a day then flush it out. Works good.
Kodiakmac
Okay.  I don't know what analyzing you've done, but from my own experience, it might not be the rad.
On my old 440 (has a 239 ci) an air lock will occur if you don't open up the temperature gauge fitting over the rear cylinder and let anti-freeze out while you're filling the rad.  Has to be done just like bleeding brakes or diesel lines when you run out of fuel: purge all the air.    If you don't do it, the rear cylinder will run hot, you'll get a high temperature reading, and eventually your engine is buggered.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
duckslayingpro
I have the 239 in mine also. I will try this. Thanks
redprospector
Quote from: Ed_K on January 20, 2014, 04:47:41 PM
Wow! I had a custom aluminum radiator built for my Fecon and it was under $800 shipping and all.
M_S_S
I don't own a skidder, but have owned a lot of Cat D7's.6's and 4's, plus numerous wheel engines. I have had to have cores rodded out before. They take the tanks off and run a rod down the tubes. I good radiator shop can do it.  KodiacMac said he had the same problem. I would check that out first. Ed
2- 562xp 24"bar
         576xp 28"bar
         385xp 28" and 32" bars
         25 ton Speeco
         6600 Ford
         02 Dodge diesel
         73 Ford 250
KyLogger
Might not be the radiator. My 440B was running hot, and I was pulling out my hair trying to find the problem. I put a new thermostat, ran it without one, put another in, took radiator out had it pressure tested and boiled out, I straightened all the fins by hand on it. Put a fan shroud on, etc.... Turned out I had an extremely small head gasket leak and it would only leak when under load especially when it was warmer out.
I only work old iron because I secretly have a love affair with my service truck!
Mountain_d
Yes, I agree with KLogger. May be a head gasket if the water pump and thermostat check out. My experience is that a head gasket leak can give erratic signals on the temp gauge.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
