Hydraulic Cooler
Started by smwwoody, January 19, 2014, 05:50:10 PM
smwwoody
I need to add a hydraulic cooler to my log truck.  The one with the Prentice telestic 33 on it.  I have A job coming up where i will need to run the loader a few hours at a time steady.  how do i size the cooler I need.
I do have a Hayden ECC209 but not sure if it is big enough to do the job.  the cooler has 1 inch lines on it and the return on the loader is about 1.5  i just emailed the pump manufacture for the specs on the pump and hayden for the specs on the cooler.
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
Tree Killer
Had sevral on serco 8500 loaders , portville truck put them on .  I googled ur part number  and didnt see the size of the cooler. The ones we  had were around 18x24  , call them ask for kelly he may give you some info on the ones the use. ?
