New Longleaf stand
Started by GATreeGrower, January 11, 2014, 03:27:48 PM
GATreeGrower
Planted Dec 7.  Last pic is the view from my tree stand, the only sweetgum I can tolerate  :D
Texas Ranger
My favorite pine, great stands, beautiful trees.
GATreeGrower
Quote from: Texas Ranger on January 11, 2014, 07:01:09 PM
It is a right cute little pine tree.  Especially when they hit that "Cousin It" stage.  :D
Were those machine planted?
GATreeGrower
caveman
Did you plant on a 5' x 12' spacing?  They look good.  When do you think you will run your first prescribed fire through them?
Caveman
Caveman
GATreeGrower,could you put this post in your FF bookmarks and take a picture each year? Be interesting to see the growth for a few years.
GATreeGrower
6x10 but theyre a tad closer than 6 feet in most places.  And the rows widen where the driver starts hitting stumps   :-\  Itll be a while before its burned.  Want enough needles on them to protect the bud.  I will keep yall updated  :)
curdog
I really like the longleaf myself. I used to work on a plantation in sc that was primarily longleaf. I think I'm going to stick a hundred or so in the ground behind the house this year to see how they'll do . I'm a couple hundred miles outside of the natural range either north or west, but there are some planted around that have made it all the way to saw log size. Will be an experiment and should do fine if I can keep the ice off of them. A guy up the road has 10-12 year old trees that are at least 15 feet tall,  but his lobs have gave them more shade then they really need.
Hopefully you'll post updates of your stand, I'd be interested in their progress.
coxy
ok no nothing about longleaf why do you need to burn them  ;D  and how  far north will they grow,  what do they look like at cut able size,  how long before you can cut them,    and pic of the tops would do me good if some one had them  ;D are they like any other soft wood   sorry for asking all this but its new to me  :) :) 8)
caveman
One of the most serious diseases that affect longleaf pine is brown spot needle blight.  The best way to combat that is to burn them while they are in the grass stage.  Longleaf stay in a grass stage from somewhere between 3 and 7 years.  They look like they are not doing much but they are establishing a tap root and preparing for the rocket stage, when they grow rapidly but are more apt to be damaged by fire.  Longleaf thrive in an environment frequented by fire.  Many of the foresters that I know recommend running fire through longleaf stands every three to five years.  When they are older, it helps keep competing hardwoods at bay and also provides bare mineral soil which facilitate the natural regeneration of southern yellow pine (including longleaf).
Caveman
Caveman
Yes, longleaf has to be burned, even when they are little, unlike other pines.
Claybraker
Quote from: coxy on January 12, 2014, 06:13:55 PM
Here's a map of the historic range. It was basically an arc from Texas to Virginia along the coastal plain.
http://www.auburn.edu/academic/forestry_wildlife/longleafalliance/ecosystem/map/rangemap.htm
My grandfather had some on his land, but they mostly got replaced when he stopped dipping turpentine, sometime back in the '60s.
GATreeGrower
If you've got wild hogs on your land I'd get rid of them before you ever set a long leaf.  They love to wipe em out after a rain.   I'm replanting some now that hogs got after.
