LT40G28 will soon be an HD
Started by DGK, January 09, 2014, 12:33:46 AM
DGK
After pondering the acquisition of a hydraulic mill for the past few weeks, I have decided to do the full factory hydraulic upgrade to my 2009 LT40. When I purchased the mill new, I added the optional log loader to assist the operation. However, since that time, the size of my logs increased from around 12" diameter to now in the 18 - 26" diameter range. Hydraulics, as well as the auto clutch, are being added to reduce the wear and tear on my body and to speed up the operation a little bit. I ordered the 3/8th hydraulic hoses where necessary, to allow for the addition of a second pump should I want to boost the speed. I guess if I do that it will become an LT40BETTERHDG28. :)
Thanks to the members whom I messaged that shared their experiences with me.
I will be sure to post pics once the parts arrive and the upgrade begins.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
highleadtimber16
Sounds Exciting!  :) You and your body will love the hydraulics!
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
WoodenHead
I hope to be doing the same upgrade shortly.  I managed to break the mill free from the ground and tow it out of its home.  The garage needs to be cleaned out to make some space.   :D
Certainly post the pictures!  It will be an interesting upgrade.  Did you get the parts for the bolt on claw turner as well?
DGK
Woodenhead,
Yes, I got the claw turner kit, roller toe board kit and the two plane clamp parts. A local machine shop will do the frame modifications for the clamp. I already had the log loader. Woodmizer is supplying everything including the Hydraulic Box, valves, hoses, etc. I am also adding the auto clutch and 2 fine adjust outriggers for the front and back of the mill. It is not cheap to do, but it will bring me to about the same price of a HD had I bought it instead of the manual back in 2009.
Doug
Yukon, Canada
Congrats, this will be fun to watch.   8)
Nothing is cheap now a days. But my pain is aggravation is worth something. Good luck to ya.  :)
pineywoods
I looked at doing the same thing, but my mill is a 95, most of the parts won't fit without extensive modifications, hence the pineywoods hydraulic mod...
DGK
Pineywoods,
If I had half your skill, I would have considered your mods. Unfortunately, I do not work with metal. Now, if I could build it out of wood, that would be a different story.
Doug
Yukon, Canada
DGK
So the parts for the upgrade finally arrived last Tuesday. I am proud to say that I now have a fully hydraulic LT40 G28 with the auto clutch. In total, it took about 5 days of working on the mill to do the change over. I started to take pics at the beginning of the teardown but then found it was slowing me down. If anyone else is considering doing the same, I am most willing to answer any questions that you may have. Thanks to Gary at Wood-Miizer Salmon Arm for putting together such a complete package of parts.
Doug
Yukon, Canada
coastlogger
clgr
DGK
Doug
Yukon, Canada
Congrats on the upgrade.  That was $$$ well spent.  smiley_thumbsup
WoodenHead
Way to go!   :)  I'm certainly enjoying the upgrade and I know you will too.
DGK
I ran the mill today and sawed about 500 ft in the afternoon of large Sitka Spruce 24"-16'. WOW, all I can say is that I wish that I had the hydraulics and the auto-clutch sooner.
Doug
Yukon, Canada
It won't take but a couple of days for you to stop waving your clutch arm.   ;D
sparks
Don't forget to add a Heavy Duty Deep Cycle battery 875 CA or higher. Original battery not strong enough for the hydraulics
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
DGK
Thanks for the info Sparks. :-)
Doug
Yukon, Canada
Dad2FourWI
Quote...reduce the wear and tear on my body...
Yeah.... I understand fully.... wise move!!!!  :)  :)
I waited until after I managed to mess up my back... still only around 90% - but I am so itchin' to start my (new to me) LT40 and have it do all the "hard stuff"!!! :D
Share pics!
-Dad2FourWI
LT-40, LT-10, EG-50, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
