Woodmizer id help
Started by arkansas, January 06, 2014, 01:25:27 PM
arkansas
  Guys been awhile but am back playing in the wood business.  Came up with a Woodmizet that
has been very hot as in fire hot and would like to figure out what model an so forth it is.  Any help please.
Working on a hot LT40HD for now
POSTON WIDEHEAD
Can you tell us a little about what you see.....or please post some pictures so we can come close to guessing what you have. :)
Thanks.
arkansas
Will do on pics. I know we all like them.  Phone to cold to work Atm. Only camera
I have right now.  Looks like all hydlic.
Is there serial numbers any where on this thing?
Ocklawahaboy
My mizer has a SN up near the trailer tongue but I don't think it would withstand a fire.  I don't  know if there is one stamped on it.
POSTON WIDEHEAD
What engine does it have on it...or can you tell?
Do you have the owners name? State,city where the mill was located? Could WM track it down that way.
arkansas
Ok, I give, pics from phone maybe more than I can do
arkansas
POSTON WIDEHEAD
If I were a betting man......I would not bet a penny on what model it is.
But I am a guessing man and I would say an LT 40. The year, just guessing.....2000 or up.
This is like a Christmas Contest.  :).......and I want some Jam!
drobertson
I believe you are right on it being hydraulic, and have to say it looks a mess. I am thinking you are more into salvage recovery than the wood thing for now ;D  hope all goes well,   david
arkansas
Hope not just junk lots of work before and AFTER
POSTON WIDEHEAD
Quote from: arkansas on January 06, 2014, 08:03:06 PM
Some people like rebuilding stuff....You sound like one of those ARK.
It'll be fun! Just keep posting pics of your progress. Before long, you'll be sawing!  :)
jamesamd
Unless the steel has been annealed  :(
I hope not so ;)
Jim
All that is gold does not glitter,not all those that wander are lost.....
Ga Mtn Man
It could use a little paint.
Nomad
     Son.  You got yourself a project there :o
WoodMizer LT50HDD51-WR
Lucas DSM23-19
mesquite buckeye
If it didn't warp from the heat, you might be able to rebuild it. :-\ :snowball:
isawlogs
I would put my 2¢ on it being a super LT40HD I would also contact Woodmizer and see what a new head assembly would cost. the bed and trailer look good to me, it still has paint, hydraulics can be refitted with some elbow grease.
  Good luck , you have a project there my friend.   :)
   Marcel
AnthonyW
Where are you guys seeing hydraulics? I see a manual log turner in the middle and nothing connected to the backstops.
I would love to see some pictures of the side it is laying on.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
POSTON WIDEHEAD
Quote from: isawlogs on January 06, 2014, 08:49:54 PM
The Supers didn't come in black.  :D
Ga Mtn Man
At least it came with a blade.
Brucer
In the first photo you can see the brackets and hydraulic cylinders for the toeboards, so it's definitely a hydraulic mill.
The square tube for the clamp is visible in all three photos -- that's the old style that preceded the two axis clamp. I ran a '96 mill with the old style clamp and I recall someone on here with a '97 mill that had the new clamp. So it is '96 or older.
The angled barce members for the outer frame are 4x4, which was the style in '96 and still is the standard. Earlier mills had a 2x2 brace. The swinging bed rails are supported on the frame with the 4x4 braces, but were cantilivered with the 2x2 braces. I don't have a date for when WM switched from 2x2 braces to 4x4 braces.
I'm pretty sure it's a standard hydraulic and not a super hydraulic. The clue is in the second and third pictures, where you can see the pulley for the carriage feed shaft. On the standard hydraulic mills the carriage feed motor is tucked down in between the feed shaft and the battery box; it points toward the frame. On the super the feed motor rises up ahead of the carriage and sticks out over the tire. Can't be certain. The best way to tell for sure is to count the hydraulic pumps in the control box. 1 = standard, 2 = super.
So, for sure it's a LT40 hydraulic, 1996 or earlier but not too much earlier. Probably a standard hydraulic.
Anyone got an older LT40 with the 2x2 bracing from the main frame to the outer frame?
Bruce    LT40HDG28 bandsaw
isawlogs
 I have the 2x2 and its a '93 , Not sure when the rollers where added to the side supports, but I do beleive it was '95 '96 ...  It is a LT40HD for sure , now as you mentioned the super will be ditermined when the pumps , or a pic of the mill from another angle.
   Marcel
Brucer
Well that narrows it down to a three year window :).
Chuck White
Definately Hydraulic!
I agree, mid-90's LT40HD!
Jim H
I'd say it's a 1997 standard hyd. That was a transitional year, the supers had the 2 plane clamp, the standard didn't get it until '98. They used the same frame with a bump-out in the frame at the clamp to allow for the 2 plane feature. A super would also have the heavier feed system.
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
