What are this?
Started by mmartone, December 31, 2013, 12:32:15 PM
mmartone
I got these from a friend of mine thinking I might be able to make them into log hook thingies (proper term).
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Peter Drouin
Straps for a ramp truck, to hold the car down  :)
A&P saw Mill LLC.
License NH softwood grader.
mmartone
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
RayMO
Very good tempered steel and should work for end hooking logs if properly sharpened.
Father & Son Logging and sawing operation .
The main problems are the limited amount of throat that the hooks have and the thinness of the hooks.  With heavy logs, tearout would be a concern.  Hooks with deeper throats allow for hooking more toward the center of the log.
clww
MM-What about if some of the bend in the "U" was removed, then re-welded back together?
18-Wheeler Driver
The possibilities are there, it's that I am not a "metal person" to talk about tempering, etc.
Where is "gspren" when we need him?
jcbrotz
I think you would be much better off to cut them off at the 110 deg mark or so and sharpen there than try welding the back together.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Before I did anything radical I would sharpen them and try them on some logs. For years before I bought logging tongs I used a similar setup only a little smaller It worked OK. Frank C.
