372 muffler
Started by Maine logger88, December 30, 2013, 06:16:51 PM
Maine logger88
  I got this muffler cheap but the exhaust exit is different and I've never seen one like this before and I was wondering if this type was good bad or indifferent?
ehp
I have seen something like that on some of the older Jonsered saws , they worked but are abit on the small size for the outlet
Maine logger88
OK thanks I wonder if I put a big tube in if it would work as well as a duel port mod
BFay2172
I don't see why it wouldn't your doing the same thing as you would be by adding a second port to the muffler at least in my opinion.
celliott
Get a deflector and add another port on the side or where the regular one is on top.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
ehp
yes any other opening to a certain size is going to help , if this is for a worksaw then use a deflector , just order one for a 288 husky and mount it on the side of the muffler which I like better than mounting on the top of the muffler , if you get to close to the top cover you will melt the cover . As far as tubes or pipes goes , I'm not a fan of them on a worksaw cause they always get hit and after a while the pipe will break out of the muffler and leave a big mess of a hole , deflector on side of muffler is out of the way from getting hit so that is the main reason I use them
Maine logger88
OK thanks guys for the input! I was thinking about moding this or an OEM muffler for my 2186 I bet that really helps those where they are bigger and still use the same muffler as a 2171/ 372
JohnG28
Use the deflector, not another pipe. One thing with pipes is increasing the pipe from say 1/2" to 1" more than doubles the area, making it harder to control the size outlet you want.
Maine logger88
Where do you get the 288 deflector can you still buy it from husky and why do you use that particular deflector?
BFay2172
Bailey's sells the deflector and screen I don't have the part number off hand though.
JohnG28
https://forestryforum.com/board/index.php/topic,69759.0.html
Check out my thread on doing the same mod to my 361. Part #s are in there. ;D
Maine logger88
OK thanks guys I think I'll order a couple deflectors and do my 2186 and 2171
