Not the best day!
Started by rockwall, December 30, 2013, 07:18:33 AM
rockwall
After walking out of the woods from trying to start the clark 664, I saw where ice sheets had slid off the barn roof and smashed the windshield and a few other things on my car. Snow and glass everywhere. So got a breaker bar and pipe and walked back into woods in hopes of hand cranking the 353, all I did was tighten the nut on the end of the shaft, it won't turn, it won't budge. Any suggestions on what to do next? The skidder has been sitting for about 2 months, it was running fine when I shut it off. Thanks for any suggestions.
DDDfarmer
Don't park under the eave of the barn.   :D
Frost can lock up a engine pretty good, is it cold there?
This is my set up for cold days.  1500 watt Honda knock off. Block heater is plugged in and hot exhaust also blows into engine bay.  Batteries also have to be in good shape for the really cold days.
No chance water got down the exhaust? Or mice/chipmunks filled up a cylinder with seeds?
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
It is a standard? The clutch good of rusted onto the flywheel. Sorry to hear of your other trouble too.
rockwall
It is cold here and it has been really cold here and it's going to get really cold for the next week. I thought the was exhaust was really good. I had a new pipe made 4 years ago and it didn't show any signs of leaks. Could be mice I suppose? Thanks for the heater suggestions.   It is an automatic.
rockwall
Actually that was a friend's 664. He figured his out, he just needed a washer in his fuel filter cartridge. I think my problem is more involved.
treeslayer2003
if there is any chance of water in the cylinders do not force it as the connecting rods in the Detroit will bend very easy. if the starter is good and batterys, then i'd say water or maybe frost......I never seen one frost locked but it don't get below 20 here very often. could you point a ready heater on the engine for a while?
rockwall
Thanks treeslayer, I think that is what I am going to try next.
JDeere
Rockwall, A simple heat solution might be to go the to local hardware store and get a piece of that 4" flexible aluminum dryer vent hose. Attach (duct tape it) one end to your exhaust on your pickup and put the other end into the engine compartment. I have done this a number of times on hard-starting cold blooded equipment and it will often make the difference. Good Luck.
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
rockwall
Woodboogah
Ill second the dryer vent.  Works well.  At least its cheap to try if you do have something more involved going on.  Good luck
Keenan Logging & Tree Care, LLC
shinnlinger
You can use the flexi pipe to blow diesel exhaust to displace oxygen  in old fuel tanks when cutting them up too.
Shinnlinger
rockwall
I went down and really inspected the exhaust pipe and where it is bolted onto manifold and I couldn't see any cracks or ways for water to get in. I did see a mouse running along the belly of the machine. Could they really plug up a cylinder? How would they get into the cylinder? I was thinking it was water that seized the motor but maybe not.
treeslayer2003
they would have to go in thru the exhaust, i'm skeptical its a mouse nest.
maybe these boys got sumthin with the frost idea? I still think i'd heat her up.
last thing to check on water is to lossen the manifold bolts......but then it will be frozen ice if it is water so won't see anything run out....hmmm heat her if ya can.
hey sumthing in the blower could cause it not to turn, ya got a good air filter I hope.
DDDfarmer
Still thinking frost.  Could be a hydro-lock with fuel-ice/water.  Chance of the clutch being stuck.....possible but I've seen tractors sit for a year-2-3 and roll right over.
Mice, seen it once.  Combine was out in the field during harvest.  Storm system came in and we covered the top of the old gas machine with a heavy canvas tarp.  Week later went to start up and thunk.. wouldn't turn over.  Turned out that the straight exhaust pipe and one cylinder was right full of barley. Nothing damaged but lost a day in clean-up.
I think the first step to pump some heat to the motor then try to turn over.  Then go from there.  Let us know how you make out.
rockwall
Miller-Thinner2
I once worked for a guy who had a heater type element that he had hooked to his oil pan he ran it from a generator for awhile before he would start the skidder. and he had some rig that hooked to the heater hoses of his half ton and it would circulated hot water through the engine,
something like that might also help out
duckslayingpro
Did you get your skidder back going?
rockwall
Not yet, it hasn't gotten above zero in a couple days. I think I'l get to it today or tomorrow.
rockwall
I did go down to the skidder and tried to turn the water pump and it turned. I opened draincocks on the oil cooler and the side of the block opposite the blower and they both dripped coolant.
rockwall
I found the culprit! The manifold gasket failed and the water is getting in that way. Any tricks on how to get the manifold off? I am planning on heating up the motor with a space heater and then trying to turn it over by hand. Do I need to be concerned about where the water goes? Someone suggested taking out the injectors first.
treeslayer2003
those bolts normaly come right out and if I remember right ya don't have to take um all the way out. if ya get it off, maybe you could poke an air nozzle in there and blow the water out as the one with water will have the valves open.
don't force the engine over, I know its tempting.
rockwall
Thanks for the tip, I am going to go SLOW!
rockwall
The best day! I went slow and heated the motor up for about an hour and a half with a space heater and then I tried to turn her backwards and she moved. I turned it about an eighth of a turn and then forward. I did that about ten times, I thought that was good enough for one day. I plan to get back to it tomorrow. I'm going slow I don't want to do any damage.
treeslayer2003
is it warming any up there? if you can turn it till the valves shut and turn it some more i'd say your fine.
Heading for a warming spell. Starting Friday into next Wed.Temps in the high 40's. I hope you will have time to work on it than.
rockwall
Warmed the motor up real good with space heater and I couldn't get it to move any further. Going to have to try taking out the injectors I think.
rockwall
I finally got my motor to turn over. Heated her up with a generator and space heater, took out the injectors and turned her over, water came out air box drain tube. So we took off blower and water just poured out. Luckily I dodged the big bullet this time, there is a broken fin in the blower, anybody know of any 353 blowers or sources to get one? Phew!
Alcranb
Great to hear! Some days your the dog, somedays your the hydrant
"Twenty years from now, you will be more disappointed by the things you didn't do than by the ones you did do.  So throw off the bowlines.  Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.  (Mark Twain)
treeslayer2003
good job, now get that exhaust leakproof.
clww
Outstanding! smiley_bouncing
Many Stihl Saws-16"-60"
18-Wheeler Driver
rockwall
From not the best day to the best day! A local guy says he has a blower and if I buy the seals and gaskets he'll rebuild the blower and help me put it in. He knows 353s real well so after we do the blower he will put the injectors back in and do a tune up. Then my neighbors from 5 miles around will hear that motor sing!
coxy
you are lucky mine had water in it and did not know it     well 1rod and a sleeve later shes running again
rockwall
We put the rebuilt blower on yesterday, put the injectors back in and set the rack. Then we put the exhaust together with all new gaskets, I hit the starter and clunk! So we got out the space heater again and warmed the old girl up again and then she turned over. It was music to my ears and even with my bad hearing I could hear the purr from the detroit, I think the neighbors could hear it too, up to 5 miles away. It was getting dark so we will go back today and get her to idle just right. What a relief and thanks to everyone for the help!
clww
18-Wheeler Driver
