Timberjack 230D looking for info
Started by logman81, December 23, 2013, 07:01:58 PM
logman81
I would like to know about them if anyone cares to share what they know about them. I'm thinking about taking a look at one in vt, from what I know about this particular one it has a completely rebuilt 353 and trans, a rebuilt rear, the heavy ones and a new full set of chains. I'm not sure on tire size might be 18.4x34 I'll find out. Any info would be appreciated.
Precision Firewood & Logging
David-L
Merry Christmas Logman81,
these Jacks can be one of the cheapest machines to run in the woods. Parts are available at auto stores and specific parts can still be had. cradle and center pins aren't bad to do. I myself would find an A model, E-model or a late D model with the bell type Eaton planetaries. that machine had Rockwells in your pics, ok but not like the Eatons. You know that these old machines can eat money up quick so look it over real good. I have a friend who buys and sells these 200 series and maybe he can help you find something. I will say a 225 or 230 or even a 240 in good condition commands a good price today even though they are 30 plus years old. I have a lot that is crazy steep and can't even imagine doing it with my old 440B, the jack on the other hand has no issues. I also like the easy in and out of the cab, tired workers are prone to accidents and I like the jacks setup. PM me and I will give you my friends #. I am in Matunuck next weekend. Oh I almost forgot, nothing sounds like a 2 stroke Detroit on the governor. music to the ears.
                                                  David L
Mountain_d
Hi David L. I am looking at a TJ230 in Ontario . It has a 4 cyl Perkins. What do you know of of that engine? The machine is a 1973.  Not sure of the model letter. Which winch do you think is best? It also has wide tires (24 inch wide) and I would prefer narrow tires. You seem to know these machines well. Any thoughts would be appreciated. Mountain D.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
logman81
Guy showed me the green so my skidder is sold. Now comes the hunt to fined a nice timberjack
David-L
mountain_D, i have a friend with a perkins and it is quiet and he like the power band. only had a few farm tractors with perkins and they started well and were ok. as far as the machine it must be a D model. Check out the hit list, cradle bushings, center pins, winch works, free spool, tranny in all gears, reverser, hydraulics. Check the planetary fluid if he will let you. A little silver on the magnetics is ok but steer away from chuncks of metal on the magnets.Ask away, I am not an expert but do know some. as far as the motor, the detroits can go quite awhile even when just about whipped.
Logman, i will ask around as I have seen a few, whats your time frame.
                             David
logman81
David the guy buying mine wants pick it up ASAP, but is willing to give me a few weeks which isn't much time but it will have to do. Thanks keep your eyes and ears open, small as I will go is a 225 and no bigger than a. 240. I'm on a small budget to
timberlinetree
Be careful of the tall narrow tires on steep hills and high stumps and boulders.good luck.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
logman81
Ok thanks, can some one explain what the difference is between the 225 model and 230? Are they the same size but with different axles ?
logman81
I think I may have found a skidder. I haven't gone to look at it yet but we have been talking back and fourth about it. From what he told it may work for me.
Maine logger88
From what I can tell is the 225 is a little shorter on the back half and they mostly had Rockwell rears the 230 had the Eaton rears although I think the older 230s may have had Rockwell as well
timberlinetree
We have a 1981 super e which is supposed to be longer than the reg model but not quite shure. Good luck.
logman81
David-L
Logman, The later model 230E was a bit longer but they are hard to find these days. thay also came with the Eaton axles and planetaries. Some of the d models came with those axle /planetary set up also. I would be looking for a 1978 and up. The A models have a different transfer case set up and the brakes are inboard and can cost serious $ to rebuild even if you do it yourself. I would run an add in the VT Agri-view farm bulletin and the NH weekly market and of course the forestry forum wanted site. After having two A models I like my flat top 1978 d model the best. It has the best visibility IMO. I will ask around as I said.
                                                          David L
David-L
logman,
Just made a bunch of calls on possible machines. Will wait to hear from them and be in touch. PM me and I will give you my cell #, Sometimes acting quickly gets the machine.
        D--
loggah
The 79 230 i had had Eaton rears and 18.4x34 rubber, the 225's usually had 16.9 x 30 rubber. I never had any issues with the transfer case ,or brakes ,or rear axles. I did have to rebuild the engine ,and replace the clutch and pressure plate once , and the nylon shifter fork inserts in the new process transmission.  They are a decent skidder if you dont mind listening to a detroit diesel day in and ouT ! ;D ;D Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
logman81
Thanks David I really appreciate your help!
David-L
Logman, PM me or call. Might have a line on something in southern VT.
                              David l
logman81
logman81
Finally going to go look at a couple skidders tomorrow hopefully their not junk .
Maine logger88
logman81
logman81
May have found a nice 230D not far from me supposed to be completely rebuilt, trying get ahold of the guy to go look at it.
logman81
So I got ahold of the guy, going to check out the skidder today!
logman81
logman81
