Home-made Fine Adjust Outriggers
Started by Ga Mtn Man, December 21, 2013, 08:50:36 PM
Ga Mtn Man
Being weak of back and too light in the wallet for the WM $1200 price tag, I decided to have a go at making my own version of the FAOs for my LT40.  I found an 8000 lb drop leg jack for $47 plus shipping that seemed like it might just fit the bill.  The jacks had to be cut down by  4" to get them down to the same retracted length as the WM FAOs and new feet had to be fabricated for the operator side ones.  I replaced the top wind handle with a big hex nut held in place with a split pin.  I've used them on a couple of jobs now and they work great.  Setting up the mill is much easier on my back and adjusting for settling during the day just takes a few turns of a socket wrench.  They are not as heavy built as the WM ones but I think they should hold up just fine.  Time will tell.  Thanks to the FF members who helped me out with some of the dimensions.  You know who you are. :)
They look fabulous Paul.  Nice craftsmanship.   smiley_thumbsup
POSTON WIDEHEAD
All you need now are BOOTS for them feet.  :D :D :D
Rockn H
Larry
Those look like they are factory made and you saved some money.  Excellent job Paul.
Quote from: Ga Mtn Man on December 21, 2013, 08:50:36 PM
I've replaced the crank handle on a winch and also on a milling machine knee with hex nuts.  Now I use a cordless to do my cranking.  I assume you can do the same.
Chuck White
LaneC
That is some fine engine-oo-ity. You sure saved quite a bit of $ too. They look very good.
Man makes plans and God smiles
Nomad
     Those look great!  And the offset foot is about as close as it's possible to come.  Glad they're working out for you. 8)
WoodMizer LT50HDD51-WR
Lucas DSM23-19
drobertson
Nice! I need to do the same,    david
lls256
Looks great!  Do you have any idea who  the manufacturer  of the drop down jack is?
This should be added to the WM modification thread.  8) Good idea.
hunz
Well done! I will definitely be doing this when the lt-35 arrives. Do you have part numbers handy? Where you purchased online?
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
customsawyer
Great job on those. Now you have me thinking.
www.thecustomsawyer.com
Qweaver
That's a really good idea to replace the hand crank with a nut.  Did you weld the nut on?
Ga Mtn Man
Thanks for the compliments guys.  The jacks were bought at Surplus Center and are made by Northfield Industries.  They have a facility in IL, so I thought I was buying a US made product.  Nope, made in China.  Still, the quality looks pretty good.  The nut is held in place by a split pin since disassembling the jack is the only way to grease the acme thread and thrust bearing.
j-dland
     Thank you GMM for this thread. As an afterthought, wouldn't it be pretty simple to cut the offset feet from the old WM jacks and weld them to the new jacks? Just a thought.
David
pineywoods
Only problem I see is "where did I leave that ratchet wrench"
Ga Mtn Man
Quote from: j-dland on December 23, 2013, 10:59:09 AM
I thought about doing that, but it would have made the jack too long.
Ga Mtn Man
Quote from: pineywoods on December 23, 2013, 12:07:09 PM
On my current job it's acting as a paper weight to keep my cut list on the hydro box, but I can see me losing it at some point :laugh:.  I plan to make an adjustment wrench similar to the one that WM makes but I'll still have to come up with some where to stow it.
I use a T handle and the WM "speed" wrench.  I regularly use both.  The WM wrench for the initial setup, and the T handle for tweaking after setup and while sawing.
Bill Gaiche
Pineywoods, he's only 51, not likely to forget like us, wheres that DanG wrench. bg
millwright
I did the same thing on my lt35 about 2 years ago with no problems at all.
orion388
Thanks Paul for getting me off my butt and finishing this little project!
John
LT35HD, Kubota L4330, Stihl 361, 026, Massey Fersuson 55, Ventrac, Grasshopper, Small dumptruck and a huge yearning for knowledge from this forum.
