Bolt Storage Bins
Started by hackberry jake, December 13, 2013, 06:58:35 PM
I'm thinking he has an NC controlled router?   :)
hackberry jake
Yeah. The faces are carved with this.
Probably not going to paint them. They are going to get greasy from shop hands anyways.
hackberry jake
I had some more time this weekend to work on bins
You can see some of the pine 2x6s I cut in the background... These boards didn't have any pith in them and they still acted up. I am going to leave the rest in log form for a while and see if some of the tension evens out.
yukon cornelius
hey jake, off the topic but I see a sign in the background that says brashears. is that a town by you? the only reason I ask is we live in the brashears valley up here in Missouri. they were a huge family. our land was owned by brashears before us. just wondering. I like the history of places. back on topic, the boxes are great! I need to make a bunch of them.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
hackberry jake
I guess it used to be a town. Now its more like a "Y" in the road with a couple chicken houses.
5quarter
I see you haven't separated the bolts into grade or threads per inch... ;) :D :D. Looking awesome, btw.
Blue Harbor Refinishing
hackberry jake
Grade and threads per inch did cross my mind. But that would be taking it just a little too far. Im not a parts store... yet... Bwahahahaha!
They sure do look nice. I need to do something with all my nuts and bolts. They use to throw away alot of nuts and bolts at my last job. I would pick them up off the floor and wait until I get a coffee can full and get a slip to take them home. I do find some that are no good,but the price is right,so I throw it away and find another one.
hackberry jake
I went to tractor supply and got a finely measured amount (handfull) of almost every size they had, Including nuts and washers. I spent right atound $150. Well worth it to stop the neverending job of hardware scrounging. Once I get the bins all made, I will go through my "bolt drawer" and sort them accordingly as well.
yukon cornelius
I like to get a bunch of bolts every time I go in there. it doesn't take long to pay for them in fuel savings alone if you are very far from the store. for me its about a $30 trip for a $.50 bolt.
hackberry jake
Bolt bins are done!
The dividers on the first shelf were just pieces of mdf glued onto the 2x10. This took a while to lay out the measurements and glue down the pieces so I just loaded a 1/2" bit in the router on the cnc and let it take out material where the bins go. This was a little time consuming as well, but I could be doing other things like glueing bins together while it was cutting. Talk about a lot of pine chips!
Talk about a good job. I would not know what to do!! I spend 15 minutes trying to find the right bolts,than 5 minutes trying to find washers.
hardtailjohn
I'm so far behind, I think I'm ahead!
DansSawmill
very nice. i do need to do that.
Dan's Sawmill
Custom Sawing since 94
CNC woodworking too
now with a 98' lt40 super
m wood
It'll be time well spent, they look great Jake
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
julio
In the last pic you have 1/2  and 7/16 washer swaped around . THAT LOOKS GREAT.. 8)
If you put your finger in your ear and scratch, it sounds like PacMan.
isawlogs
 I would need a much, much larger MISC bin, like way bigger  :D :D :D
That looks really good.   :)
   Marcel
