Making a 262 out of a 261
Started by Maine logger88, December 08, 2013, 10:31:35 PM
Maine logger88
I just picked up a 261 on eBay  to turn into a 262xp for an evening project from what I understand I need a 262 piston clutch and muffler to make a 262 is this correct?
SawTroll
Information collector.
Maine logger88
OK thanks just wanted to make sure!
Spike60
If you change to the 3 shoe 262 clutch, you're also going to need the spacer washer. (I can look it up tomorrow if you need.) The 2 shoe clutch has an offset and so doesn't require the washer.
If you want a little more snap, use the base gasket from a 254 which is 1mm vs the 2mm gasket that you have in the 261. Part number is 503704801.  :)
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
nmurph
I've done several conversions without changing the clutch. The two shoe seems to hold up fine. I would just run it and if it fails, then spend the $45 to replace it.
The muffler is also different. But it is fine as is if you do a little bit of mod work. Open the existing opening inside the can and enlarge the slot on the front.\
I picked up a 261 this weekend and it will be a 262 in short order.
Maine logger88
OK thanks guys my cousin may have a blown up 262 I could get off him for parts cheap which would be good spike if you get a chance to I would like to know what the spacer is in case I can't get my cousins saw. so the 254 gasket will give it a little better compression? nmurph so by doing a little grinding the 261 muffler will work just as good as a  262? So I'm assuming that these saws are a closed port?
SawTroll
Quote from: nmurph on December 09, 2013, 08:29:35 PM
Surely, but with those shortcuts it doesn't really become a 262xp, just a 261 with 262xp engine performanse... :D :D
nmurph
Quote from: SawTroll on December 10, 2013, 05:24:24 AM
Using that logic, nothing will make it a 262 short of a new SN plate. I think the idea is to have 262 performance...that's all that matters to the tree.
Spike60
Husqvarna-Jonsered
845-657-6395
NCFarmboy
Agree w/nmurph I too have several down to 4.  Meteor 262 piston is all you really need.  The 2 shoe clutch will be fine.  I have done 7 of these conversions for the record.  I have 2-3 shoe clutches but why bother if the 2's work just fine.
Shep
Lots & Lots of Saws
Spike60
Piston is obviously the most important followed by the muffler. Changing the clutch is not really necessary. If it fails, then by all means upgrade to the 3 shoe. But if it's OK, then just leave it on there. It'll be fine.
Husqvarna-Jonsered
845-657-6395
SawTroll
Quote from: nmurph on December 10, 2013, 06:33:04 AM
True.  8)
Maine logger88
Thanks for the help guys its supposed to be here on Monday or Tuesday I'll post some pics when it gets here
cheeves
I did one from a 261 I found in a dumpster! It's now my favorite firewood saw! Looking for another. I love it!!!
Spike60
Quote from: cheeves on December 12, 2013, 11:30:26 AM
I did one from a 261 found in a dumpster! It' now my favorite firewood saw! Looking for another. I love it!!!
That's a super score. How many times have you been back to check that dumpster?  :)
Husqvarna-Jonsered
845-657-6395
Maine logger88
  I got it today its in pretty good shape I talked to my cousin today and he said he would look for his blown up 262 tomorrow hope he can find it then all I would need is a new piston and I'll be good to go
