Socially And Technically Correct Nomenclature
Started by YellowHammer, December 02, 2013, 07:59:27 PM
YellowHammer
This weekend I was sawing a customer's pecan log and after the customary "No, there can't be any metal in it" I got down to about the third board and the saw blade started zinging with the sound we all know and hate.  There were so many nails that I could have sold the log for scrap iron.
So I called the customer to describe how many nails were in his log and all I could come up with were a few technically accurate but certainly socially incorrect terms.  ;D.  So I checked the FF dictionary and came up empty (or at least I couldn't find anything).
Questions is: what is the technically correct and socially acceptable nomenclature for a large quantity of nails in a log? Not just one or two nails, but so many nails it looks like somebody was given a hammer for their birthday?
Herd?  School? Flock? Gaggle? Nest?  Bucket full?  Junkyard?
Thanks for your help,
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Dave Shepard
It depends on who owns the nails. If they belong to your customer, you have found "An Inconvenience" of nails. If they belong to you, they are "An Aggravation" of nails.  :)
Chuck White
Andy White
YH Maybe an old school carpenter,"if one nail is good, then a bunch would be better!" So put on a new blade and saw saw saw. Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
samandothers
It it was a butt log you could indicate a butt load of nails!
drobertson
You could bet a barrel of nails that is was a "Butt Load of Nails"!    david
Barrel?  Keg?
All these nails could drive a man to drink  :D.
terrifictimbersllc
mikeb1079
sounds like some walnut logs i sawed awhile back....they were absolutely infested with nails.   ::) :D
homebuilt 16hp mill
If I found that many nails, I would forget about the "Socially Correct" part.
Nails are bad enough, but nails and Pecan ( smiley_devil), that is just not fair  :'( >:(
An infestation?  I like it!
YellowHammer
There was definitely  ;D some socially unacceptable cussing going on, as this log topped off an otherwise bad day.  Bama had just lost THE game and I had been wanting to get this little bitty nasty looking pecan log done for a customer, so figured I'd do something productive and work my frustrations out.  I put a new blade on, cut the very first slab and it popped sideways out of the board return and dismounted the running blade in a screech of metal.  Put a new blade on, made a couple of cuts and then ran into the "____" of nails.  One log, two blades, 3 boards and I was done for the day...
YH
YellowHammerisms:
Brucer
I'm afraid I don't have a suitable adjective. However ... sometimes a phrase will convey a concept much better than an adjective. When a customer asked why I hadn't sawn her log, I told her I ran my metal detector over it and "it sounded like a geiger counter at Three Mile Island". (substitute Chernobyl or Fukushimi, depending on the customer's age ;D)
Bruce    LT40HDG28 bandsaw
Brad_bb
Not to add salt to the wound, but seriously want to know whether you ran a metal detector over it first?  If so, did it pick up the metal or not.  I don't have much experience here, so I'm just trying to find out.
highleadtimber16
Timber from the mountain has it's benefits   :)
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Tom L
Quote from: terrifictimbersllc on December 02, 2013, 09:48:53 PM
A "hardware store ". ?
I like this one, ^^^^
"that log has more nails than a hardware store"
YellowHammer
Quote from: Brad_bb on December 03, 2013, 12:44:43 AM
Well, to add a little more snakebite to the day, I have two metal detectors, a wand and a coil.  When I got ready to saw the log I checked it with the wand but found the battery was dead. So I grabbed the coil and swept it and came up with nothing. My wife commented that I had remarked earlier that I didn't trust the coil detector so why not wait until we went to the store to buy a battery for the wand?  Well, me being impatient, said the famous last words "I don't want to wait, how bad can it be?'  I suppose I found out.
YH
YellowHammerisms:
Deese
YH--If you would have taken an "extra second" to go get those batteries, you could have avoided the frustration  ;D
Sorry I couldn't help myself ;D  ;D
WAR EAGLE!
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
PC-Urban-Sawyer
YH,
Now let me get this straight...
You tried to scan with a wand which works well when it has fresh batteries but found the batteries were dead, so...
You scanned with a coil, which you had previously informed your wife was in your opinion untrustworthy...
And the coil said it was clean...
And your wife (being the intelligent creature she must be to have married you...) asked if it wouldn't be a good idea to wait until you could get fresh batteries for the wand because you said you didn't trust the coil...
And you said, to misquote one of my Naval heros: "DanG the nails, full speed ahead!" since after all, how bad could it be?
Boy, I be you've been ate up with "I told you so"s from that intelligent lady.
:D :D :D :D
Herb
chickenchaser
Quote from: Deese on December 03, 2013, 09:31:01 AM
WAR EAGLE!
Mr. Moderator - we shouldn't have to tolerate actions such as this! This poster needs  ban_smiley....
WoodMizer LT35HD
JD 3720 w/loader. 1983 Chevrolet C30 dump. 1973 Ford F600 w/stickloader. 35,000 chickens.
chickenchaser
Quote from: YellowHammer on December 03, 2013, 08:47:42 AM
I have two metal detectors, a wand and a coil...
...I had remarked earlier that I didn't trust the coil detector
I've read differing opinions on each. Is the lack of trust due to something related to your particular coil detector or would you prefer the wand regardless?
CC
WoodMizer LT35HD
Sixacresand
It would be tempting to just say "you owe the cost of a band if it can't be sharpened". As Postonlt40hd posted recently,  you will find more metal with a blade than with a metal detector.
