timberjack blowes trans filter off
Started by Nemologger, November 26, 2013, 10:31:27 PM
Nemologger
My cousins 240 has started blowing off the transmission filter, I think its an Allison. Anyone have any ideas?
Clean and Sober
treeslayer2003
I had a clark trans blow the fluid out the vent. the vent wasn't just a vent, it was also a check valve. new valve fixed it, just a thought.
Autocar
If it has a canister and the filter is in side check the little flat rubber seal plus the O ring seal I had a problem like it and that was my problem the one seal was bad.
Bill
kiko
Is it a spin on or canister? Trans pressure regulator could be sticking, or in the case of a spin on filter the threads on filter housing could be damaged just enough to tighten filter but allow to be pushed off.
