Sharpening Shed Size
Started by rmack, November 26, 2013, 09:44:21 PM
rmack
I have some lumber that I sawed up this summer/fall and was thinking of building a small/portable storage shed that I could eventually use as a sharpening shack. What would be the smallest shed that would still be useful for sharpening/ storing blades? how would they be set up?
I have a 5 ton forklift so I can move a fairly heavy shed.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
m wood
If you can move it then its portable...shouldnt be zoning issues, right?  BUT, as has been said here many times, if you build it just the right size the first time, it will inevitably be tooooo small.  Go BIG, then add a couple of feet to the dimensions, put it on paper, stand back, scratch your head while considering all the stuff thats gonna end up in there, throw away the paper IMMEDIATELY and aproximate DOUBLE what you previously were thinking :).  Thats how I do it anyway :D.
if your sharpening there must be a power supply. I guess all thats needed is a heavy extension cord if its gonna be moved around and what-not.
But seriously, I set up occasionally and sharpen in my wood shop.  I have to clear everything for about 8 feet in the area and I still feel cramped.  I never fold my blades back up and just hang them and transport them in a big circle.  they do take up space.
others here will have better advice (and less sarcasm) than me, I'm sure.  Good luck with that shed
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
ladylake
Maybe 8 x 16 or so.     Steve
Chuck White
I was thinking maybe 10x16, then saw Steve's suggestion of 8x16, so I would suggest 8x16 as a minimum.  ;)
Keep in mind, you will use the space regardless of the size you build!  ;D
rmack
I was thinking 8x8 or 8x10... guess that's not going to work.
I'll just build a storage shed then, will be good practice getting a design that is sturdy, yet easily portable.  :)
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
dboyt
It might start out as a sharpening shed, but you'll probably store your blades, cant hooks, chain saw, winches and other tools in it, then rebuild the engine on the firewood splitter (which will remain in pieces for months), then your wife will decide to store the garden tools in it.  Next you'll set up a planer.  You will wind up resharpening your blades outside.  Oh, wait... that's my shed!  It probably never happened to anyone else.  :D
goose63
Quote from: dboyt on November 27, 2013, 08:52:08 AM
Ya right happen's here all the time
goose
thank you to all the vets
ely
I think mine is 22 ft square open fronted sharpening shed, concrete floor, so full it has trails to get around.... talk to me about filling up a shed... back when I was 16 or so me and dad laughed about standing on junk in the shed we were putting up the trusses on.
jackpine
 My sharpening/blade storage room is 12 x 16 and even at that it feels crowded at time especially when coiling and un coiling blades or turning them inside out to set. I have 20" benches along both 12' walls so in effect the room is more like 12 x 12. As others have said, do not underestimate how much room you are going to need.
Bill
21incher
I don't know if you have any local building codes, but where I live any temporary shed over 120 sq. ft. ( that is not a tent style shelter ) requires a building permit so you may want to take that into consideration. You can build 3 - 120 sq. ft. sheds with no permit but if you build 1-125 sq. ft. shed it requires a permit and I think it is also added to your assessment and taxed.
customsawyer
I have a 30'X40' shop and it seems small. Keep in mind that I run a two sharpeners and the band roller so those things take up more room. I have a some extra room but not as much as you would think. There is several other things in the shop also so they might be the reason I don't have as much room as I think I should. ;)
www.thecustomsawyer.com
POSTON WIDEHEAD
Quote from: customsawyer on November 27, 2013, 07:42:29 PM
That's a BIG skating rink you have too!  :)
Banjo picker
That is in the corner of a 12 x 16 building...I only have a single tooth setter so I need some room to flip a band if I don't want to go outside.  It was built for guest to stay in, but they always wanted to stay in the house with us any way so I converted it...Always got stuff stored in there for what ever reason. Banjo
dboyt
Quote from: Banjo picker on November 28, 2013, 03:53:09 AM
They probably couldn't sleep in there with you sharpening blades all night. :D
barbender
  :D Good one, dboyt :D I built a 12'x16' shed that my sharpener ended up in, and I find that it would be adequate for a sharpener and setter set up and some blade storage, IF you keep everything else out of there and keep it well organized.
Banjo picker
I wish I at least had the chance to dull some... I got a freeze plug leaking ...and cant run ...logs on the deck for myself and cant cut them... getting parts for a Perkins is a pain.
backwoods sawyer
Quote from: Banjo picker on November 28, 2013, 09:31:08 PM
Getting rebuild parts for the perkins has been a real pain, a year later motor still at rebuild shop awaiting parts :(  good luck hope you have a speedy recovery. You got a back up motor if need be?
Backwoods Custom Milling Inc.
Banjo picker
I got them ordered.  The dealer from this area had to get them from a larger dealer... Perkins dealers will NOT sell out side of their area.  I will NOT buy anything else with a Perkins in it.     >:(  Sorry for the hijack....Banjo
rmack
Quote>:(  Sorry for the hijack....Banjo
don't worry about it :), btw there seem to be a lot of perkins sources out there if google is any indication. I had a late 70's welding machine with a 4.154 in it, never had any troubles finding parts.
I have a few 12"x12"x18' timbers, think I'll cut one in half and build something 12'x18' ish on skids. I'll try work it so that I can drag it onto my car hauler and use that to move it when necessary.
I'm wondering if anybody knows what this type of roof is called. I'm looking for framing tips. the red dots are where windows would be. (too lazy to get autocad out)
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
barbender
I think that's a clerestory, Bob.
Delawhere Jack
Rmack, you need to put a stick figure  um, dot figure person in that drawing for scale.... ;D
rmack
Clerestory it is, thanks!  :)
QuoteRmack, you need to put a stick figure  um, dot figure person in that drawing for scale.... ;D
done  ;)
just above freezing and rainy today, managed to get the barest start on things anyway.
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Lud
As I read this thread, I noticed nobody's talked about heigth.   The upper floor I put into the north end of my bank barn some years ago is probably eleven foot so the joists are ten foot and I  hang the blades from two spikes to "keep the round".   I can walk right under them and with multiple sets of spikes I have lots of sorting options of To Do, Done, Repairs, etc.
Just hoping to give you something to consider. 8)
