what type of metal is a 026 muffler made out of
Started by ladrhog, November 23, 2013, 11:07:19 PM
ladrhog
I was thinking about doing a muffler mod and welding a couple of ports on a stock muffler.  I have a big welder just need to know the metal type to buy some filler material.
**new to me ms441**
ms200t
ms362
ms260
026 pro
024
Pioneer p-41
JohnG28
Oliver1655
"Big welder"???  I use a MIG set for 20 gauge steel.  A lot of folks braze or silver soldier.
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
I'd think steel too, a magnet will tell you quick enough. If it stainless or alloy a magnet wont stick.
sablatnic
ladrhog
man,   you gotta love auto correct.   i meant tig welder.   i will try the magnet thing.
**new to me ms441**
ms200t
ms362
ms260
026 pro
024
Pioneer p-41
redfin
They are steel. I added a baffle to mine after I opened it up because I didn't like how tinny and loud it was.
JohnG28
Quote from: redfin on November 24, 2013, 02:49:43 PM
Isn't that a little counterintuitive to doing a muffler mod in the first place? ???
redfin
Quote from: JohnG28 on November 25, 2013, 10:52:57 AM
Counterintuitive would have been making the baffle smaller than the original opening. As I stated I made the baffle because I didn't like the way the saw sounded.
The openings in the baffle are 100% of the port opening which is what I was shooting for.
motard
Why Stihl of course.
Don't have a tig, but silver solder works real nice.
nmurph
Quote from: redfin on November 25, 2013, 11:00:52 AM
Well, 100% or not, that baffle definitely restricts your saw. BTW, 2 smaller openings do not flow as freely as one larger opening of the same area. The smaller openings will have more edge which creates turbulence and drag on the flow.
redfin
Neal, I agree with what you are saying 100%.  When originally opened the muffler on this saw it was around 165% and the saw would not idle nor rev to what I thought was right.
I did a lot of reading about larger holes verses more smaller ones.  I decided to build this baffle because of the sound.  There are 4 holes and the saw does what I think it should now. Not saying its the best way, its just what worked well for me.
H 2 H
Here is what I came up with
I took off little at a time till I found what I liked best it's about 120% of the cylinder opening on one of my 026
Brian
Old BROWN eyes strikes again !
"Saw troll speaks with authority about saws has never even touched. Well maybe he touches the pictures in the brochures before he rips on them"
".... guess you need to do more than read specs, and look at pictures !"
JohnG28
Quote from: nmurph on November 25, 2013, 03:19:15 PM
That was sort of my line of thought. Still made a maze for the exhaust to travel, which is the opposite of what a muffler mod is intended for, IMO at least.
That was my thoughts as well. Made a maze for the exhaust to travel. IMO this is opposite of what a muffler mod is intended for.
nmurph
Quote from: H 2 H on November 25, 2013, 06:16:09 PM
That's what I'm talking about, Brian!!!
GAB
Ian:
I've always been told that 300 series stainless steels were not magnetic and did not rust, and that 400 series stainless steels were magnetic and also rusted.  Have I been told wrong?  Gerald
nmurph
redfin
What did you measure your port opening to?  Iirc mine was somewhere around .30".
Al_Smith
It's rather an unconventional method of modifying a muffler but it's not my saw nor my business how it's done .
However generally speaking much over about 85 percent of the area of the exhaust port really adds little to performance other than noise which doesn't do anything but hurt your ears and annoy the neighbors .Might make hounds howl too .
The way that baffle is tacked in there with those little holes you could have half the front cut off the muffler and all that would get through is though those little holes .So a hole 100 percent or 500 percent would not make a hill of beans how it ran ,can't get through the baffles .10 pounds of taters in a 5 pound sack thing .
redfin
Maybe I will try some different openings to test with. I have an ir temp gun and can test cut times.  I aslo have a tach to verify where the rpms are after each change. Just when I thought this little guy was running good. Haha
H 2 H
How a measured the open -I put grease on the cylinder exhaust port and transferred that to paper by pressing the paper to the opening
I started the MM roughly around 80% then run the saw (cutting something) and just keep taking more material out till I find what I want all saws are a little different and that's how I got up to what you see in the picture above
Brian
FWPT
Quote from: redfin on November 25, 2013, 03:56:22 PM
Have you re tuned the carb each time a change was made??? re tuning should have gotten you the proper idle and spool up rate.
Husky 42 special ported(screamer)
husky 372xp xt muff modded
redfin
Quote from: H 2 H on November 27, 2013, 12:32:30 PM
I got you,  I measured using the opening where the piston touches the cylinder wall and looking at my notes it was .32".
And to the above question, yes I retuned.  I messed around with the low speed and idle adjustments for what seemed like hours.  I even press/vac tested thinking that may be the problem.  Don't get me wrong the saw to someone else may have been just fine the way it was but to me it could be better.
After messing with it for awhile I closed the original port down to about 100% and the saw did what it should.  That's when I came up with this brainstorm to make the baffle to quite the saw a bit.
Now, with all the above mentioned posts regarding how I have hindered my saw with the baffle I am going to build a flow gauge and test with this saw.  If nothing else, I will learn from my mistakes.
H 2 H
FYI - when doing a MM you'll have to really open up your "L" on the carb
One of my saws says to start at one full turn on the "L" screw on the carb but this saw didn't start running good till it was 2 1/2 turns out
Brian
Al_Smith
You have to keep in mind how a pressure can muffler  works .In addition to muffling sound it's also a pressure regulating device .
If you cut a giant hole in the muffler all you will do is over run the low speed jets' capability to supply fuel because it "short circuits" at idle speed .If you choke it down with a bunch of baffles it cannot wind up .About like trying to squirt water from a 3/4" hose necked down to quarter inch .If it can't get out it can't get in.Just the way it works .
So now comes the big question .Well then just why could they run old Macs and Homeys with open exhaust---because they had giant carbs not itty dinky ones they use today .
