Dodge Recalls 1.2 Million Trucks
Started by pappy19, November 23, 2013, 01:13:58 PM
pappy19
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
m wood
my '98 just turned 280,000 miles.  Dont know how many new rods and ends it has had put on.  I've done one entire set myself.  The whole front end for that matter.
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Jason_AliceMae Farms
Thanks for the heads up Pappy, I'll have to take a look at my '05.  Might be time to do some 'upgrades' if I am on the list.
Watching over 90 acres of the earth with 50 acres being forest.
Someday I would like to be able to say that I left thes 90 acres healthier than when I started watching over them.
ST Ranch
Front end steering suspension parts on my 2005 Ram 3500 diesel 4x4 have been an ongoing problem for me - I do not know if it is the heavy Cummins or what, but I have redone my tie rods and and drag links twice in less than 100,000 miles. First time it happened, fortunately I was on a bush road and only going 15 mph or so, tie rod popped out of the socket and front tires spayed outwards like doing an awkward splits. - I replaced them myself with MOOG parts, but they failed again, but fortunately lifetime warranttee. I now watch them closely to avoid a repeat. Dodge have an upgrade package, [heavier duty parts] but about 1000 bucks just for the parts - we will have to see what this recall brings.
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
Mooseherder
This recall happened a few years ago as I remember.  I was upset they didn't include an alignment.
Our 2004 has 120,000 on it.  I hope to get much more out of it.  Our grocery getter eats u-joints.  It's the Allison slamming it into overdrive.
Maybe we should spread it out into two loads. ;D
NWP
My 98 Dodge ate front ends. Probably put 5 in it. Tie rods, stabilizer rod, ball joints, etc
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
pappy19
Apparently the earlier recalls were not the best fix, but this new one is better. I had a buddy that lost a tie-rod on his 2005 and almost went in the river. Here is another article from Moter Trend with an 800 number that should answer some questions.
Pap
http://wot.motortrend.com/1311_chrysler_issues_massive_recall_for_ram_hd_truck_tie_rod_assemblies.html
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
SPIKER
Pretty much every dodge I been around has had major front end issues, and wheel bearings hubs brakes, just constant issues.   The front wheel drive stuff K members rotting thru suspension arms rotting out all withing 7 or 8 years...   Neighbors Neon had 80K on it, 2004 lower control arm mounts to K member rotted off from AC dripping on it...   ::) :o
Wont own one myself too many problems from all the people around me that bought them...
Reddog
