Thinking of buying a log rite
Started by Cguignard, November 22, 2013, 02:55:03 PM
Cguignard
After fighting with my old peavys and reading about everyone's love for them, I am thinking about ordering a 60" log rite.  My only question is has any one ever kinked the wall on there 60" I use my 60" wood handled cant dog for flipping large pine and lifting up the end of logs to put blocks under to account for taper.  And also slide my cants around to catch the next bunk. Just wondering if anyone has had any issues?
Worried about bending it when I get my shoulder under in and start lifting.
A don't see how a man can bend one. Now hook a tractor or a truck to one.................. By the way you are using a peavey in your picture. Peavey starts with a "p" for point. The Logrite site will tell you the diffenace too. I myself grew up with a peavey. The point comes in handy to pry the logs apart.
And I use my tractor to flip logs that size too. I am impressed.
I have heard of some that have put a wheel on top of the dogs.
I have a Thomas sawmill. I have no idea how your log dogs are. But mine go straight up and down. I have marked inches on them. From 3 to 8. Really 4 inches is 3½. I took of a half inch on each mark, This way when I am saw my flitches or put a log on,if my dogs are set at 6 inches and I saw 6 inches I know I will not saw into them.
Lay your worries aside.  You will not bend the Logrite handle.   logrite_cool
Give Tammy a call and tell her that the Forestry Forum sent you.  LOGRITE
Dave Shepard
I have a 60" and I put it under the end of 30' logs to lift them up to shim the end level. Sometimes I have to lift with all I've got. It will deflect a little, but it won't kink.
dboyt
Keep your old peavey and pick it up once in a while, just to remind yourself how much the LogRite spoiled you!  Looks like you've got some respectable logs to mill.  Nice sawmill, by the way.  Used Norwoods are hard to come by.  You'll make a lot of sawdust with it!
T Welsh
Money well spent! I have had a 12,000lb winch hooked to mine rolling a large log onto the mill and it worked fine.Mind you I hooked it down at the bottom. Tim
Deese
Are they they lighter than some of the others? I use one (not log rite) that came with my mill, and man it is HEAVY  :o :o
I cringe whenever I see it propped against the wall :-\ :-\ Plus, the handle is made from square tubing. I DO NOT LIKE IT >:( >:( >:(
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
jmouton
    we havent  used anything but logrite  ,  they are prettty light and really strong we have 2 48" long  and i pry all sorts of logs with them and they havent broke yet , I really abuse them ,  I really need a 60" but just havent got around to buyin one yet
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Hilltop366
I have a 48" , I find the grip kind of large for my short fingers, and the hook a bit large for smaller ( 8-10") logs. That being said it seems very tough and works well with the larger logs.
Your pictures tired me out.
Nomad
     One man isn't going to put a bend in a Logrite by hand.  Period.  I don't care what you try to do with it.  I'd have to see it happen before I'd believe it.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Dad2FourWI
 I purchased a Logrite 60" with my mill and found it so useful, I purchased a 2nd one!!!
I have to admit that I do abuse mine... I use it to pry logs up out of the sand when cutting (to keep my cs blade out of the sand here)... I even ran one of them over with the tractor! (not on purpose!!!! :) )  and after I dug it out and looked it over... it was fine!!!! (whew!!!!!)
Well worth the money!!!
Hey, Magicman.... if we mention the FF, can we save some $$ on a purchase??? (hmmmm, what could I do with another one..... LOL!!!!)
-Dad2FourWI
LT-40, LT-10, EG-50, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
Sometimes Tammy will be able to secure a scratch/dent, etc. at a reduced price.  I think that I saw where WM is offering Logrites at a 10% discount at the present time.
thechknhwk
Quote from: Hilltop366 on November 22, 2013, 05:47:30 PM
You need the 3 footer with the smaller hook on it.  It makes way quicker work of the smaller stuff.
thechknhwk
Quote from: Dad2FourWI on November 22, 2013, 07:03:45 PM
-Dad2FourWI
I ran my 60" over with my 3/4 ton truck and all it did was twist the log stand (for lifting firewood) on the handle a bit.  I adjusted it and retightened and all is well.
POSTON WIDEHEAD
The worst think about considering to buy a Logrite is considering.  :D
YellowHammer
There are many opportunities in life to second guess a purchase.
This isn't one of them.  Get it, use it, forget about it, worry about something else. ;D
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
redbeard
I always get a big smile when someone new is helping around the mill and they grab the 60" log rite can't hook and use it for awhile moving logs. It doesn't take long there asking questions and bragging about how nice this tool is.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
losttheplot
Quote from: Cguignard on November 22, 2013, 02:55:03 PM
Lumber mate 2000 has big washers on the top of the back stops. They can be replaced with bearings if you want to.
If your not already doing so, move the cant away from the back stops before you try to roll it.
That way you are not trying to slide the bottom of the cant on the bunks, as well as the side of the cant on the back stops.
Build your self a manual log turner/loader.
I pick up my 60" logrite over my wooden handled one every time, cant fault it.
DON'T BELIEVE EVERYTHING YOU THINK !
Cguignard
As I worked through that bunch of logs I started to push back from the posts. The log posts on my mill are a custom set up that pivot up from a bracket bolted to the bunks, the owner reversed rotation of the mill so the discharge is opposite of the side you walk, and he made this log post set up.  They worked great but have gotten a little out of square. Once the ground freezes I am going to level the mill and square them up to the bunks.  But I like the washer idea going to have to make a mod to the posts and install some.
NWP
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
mobile demensia
Don't think, just buy. Well worth the money. If you buy one and are not happy I will take it off your hands no question.
Timberjack 230D
Mobile Dimension 127
Woodcraft 30-20a
2 Stihl 660's
and growing
Brucer
I have a bent 60" Logrite. The customer supplied me with a helper. His job was to buck the 24" diameter x 50' logs into 16'-8" logs. He disappeared behind the pile with a chainsaw and my Logrite. I heard the saw for a while, then silence. After some more silence I went to see if he was OK.
I found him trying to roll an 1800 pound log that was settled on top of two other logs. He had the Logrite sticking straight to the side, his hands wrapped around the end of the handle and his ankles around the base of the handle. He was bouncing :o. The log would move an inch and roll back. After a few bounces he'd give it a really hard bounce and the log would move 2" -- and roll back. The guy weighed about 180 pounds.
Turns out he'd spent 5 minutes bouncing on the Logrite, trying to get the log to roll off. I asked him if he'd thought about what would happen if the log actually did roll off. Apparently he hadn't.
At the end of the day I noticed the handle was bent just where the bracket is attached. I consider that to be way, way beyond normal use. It isn't bent much and it's still useable. I use it quite often to pry up the end of the log, hoping it'll bend back the way it was in the process. It's not working.
They aren't invincible, but they're pretty darn tough. I'd not hesitate to buy another one. So far three seems to be enough ;D.
Bruce    LT40HDG28 bandsaw
With a manual mill, the 78" mega-logrite is indispensable for turning big logs.  It is amazing what you can do by yourself with one of those.  You also need a 60" logrite for turning normal logs.  You won't believe how good they are to use.
Really.
customsawyer
Get two while you are at it. Once you have one you will want another.
www.thecustomsawyer.com
