Hauling Firewood-Lets see your rig
Started by spinner, November 11, 2013, 07:25:17 PM
spinner
Heres my ol girl, 1981 gmc sierra classic, 3/4 ton 4x4. 350 propane powered 400hp, 4speed manual. 362 stihls bought last year.
spinner
NWP
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
spinner
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
ga jones
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
That loader looks a little big for that truck,  ;D   but looks mighty handy for the reach it has.
ga jones
It's a bit big.i had to build a mount off the back to store the grapple.works good on the landing.
ga jones
ga jones
SLawyer Dave
Well the focus of the pics was supposed to be the log I was trying to give away at the time, but you can see my rig.  It also doubles as my log trailer, with a winch that attaches to the front and an elevated cross bar with a snatch block that fits in the rear stake pockets.  My wife hates that I used old crating to make the sides and threatens that she is going to have the grandkids paint the trailer, because "it can't look any worse".   :D
SLawyer Dave,tell her to go buy you a "better looking" one than.She'll come back home with her tail between her legs when she see the prices.  ;D
My wood hauler is my tractor now. I use to haul wood from here to my other house with a truck.
Roger2561
That's a 1/2 cord firewood on that pallet.
Roger
Roger
1/2 cord? What are the dimensions?
I haul on pallets, with about 1/5 of a full cord on each. About one week's worth to heat the house.
Here are two pallets stacked.
Roger2561
Beenthere - the dimensions are 4'X4'X4'...  I fill the pallets (I built them myself) as I'm splitting the wood.  When it's full I drop it the field; grab another pallet, fill that one, drop it in the field; etc...  I cut all of my firewood at 24" long.  I have enough on pallets for this winter plus the next 3 winters.  I may not have to purchase another load of logs until 2015.  Roger
Roger
Looks good, and easy, and efficient. smiley_thumbsup
Do you have a strut or wire in tension across the top to hold the 2x4 end-frames together?
Roger2561
I love the color green that's on your tractor.  What model do you have?  Mine's the 4500.  Bought it new in 2000.
I have a 2" wide webbing running across the top to keep the uprights from falling apart.  I think it's rated at 2000Lb tensile strength.
That is one heavy load.  The first one I moved I didn't have any counter weight up front.  Every time I hit a bump the front end would come off the ground about 3 inches.  That was a bit unsettling.  I filled the loader with a bunch of cement blocks I had around the property and that kept the wheels on the ground where they belong.  Plus it's easier to steer when the front tires are touching the ground.
Roger
Dave Shepard
brendonv
I wish i can find some sort of large tub to fill with half a cord then set behind the garage with my loader.  Thatd be really nice.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Roger
QuoteWhat model do you have?
It's a '68 1998 model 4300. Really like it for many of my jobs.
I too had to add some counter weight, but to the snow plow blade. I had a choice to remove the snow plow and put on the loader to get the top pallet off the bottom one (which is only about a 20 min. job at most), or add some weight and move the two pallets so this is what I did. Picked up the ballast box with the plow.
gspren
Quote from: beenthere on November 12, 2013, 06:04:35 PM
Roger
It's a '68 model 4300. Really like it for many of my jobs.
  Are you sure that it's not a 1998? It sure don't look like a 68.
You are correct... that is a typo... 'tis a '98  -----  thanks, and I'll correct it.
Since I live 45 miles away from my firewood source, mine has to be trailered.
Magicman,Is that a "winters" usage  :D
WmFritz
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
