Kohler command 27 key
Started by Bigbo1234, October 27, 2013, 08:32:47 AM
Bigbo1234
I lost the keys to my mill. Is this key something i can pickup at the hardware? Or is I something to order from Timberking or Koehler directly. A screwdriver will work for now, but it doesn't look very professional.
Bowen
Chuck White
I would think that you could get another switch at an autoparts store.
I don't think there would be anything special about it, unless it's the size!
I alway though not much diffeant in keys with them small motors. That is why the screwdriver works. Any place that sells Koehler should be able to help you. Get your model number and serial number just in case you need it.
goose63
Try a riding lawn mower key those seam to be all the same :snowball:
goose
thank you to all the vets
sawguy21
If it is the flat T shaped Indak key it is common to almost every brand of lawn tractor. Allis even used it on farm equipment, a $250,000 tractor with a $10 ignition switch. ::)
Bigbo1234
Turns out the local hardware had some. It's your basic small egine key I guess. Funny thing is the keys I lost had my truck key, house key, some pad lock keys and the mill key. I was only worried about the mill key. ( an th cool little screwdriver/spark plug gap tool that held them all together.) Still a bummer tho. If any of you happen to see my keys, please let me know I would appreciate it. ;)
Bowen
You found a replacement for the "important" one.   ;D   :D
Most Kubota tractors, in several year blocks, use the same key.Expect the dealer to ask a few questions when you buy them. Frank C.
dboyt
I thought I found your keys, but they were for an old Studebaker I sold years ago.  Hope you (or a FF member) finds your keys.  Screwdriver will also work for your pickup, if you don't mind driving in circles, and climbing through windows can be a real pain.
