husky 372
Started by coxy, October 26, 2013, 08:09:36 AM
coxy
why does this thing keep blowing the muffler apart the saw is little over a year old and put 4 of them on it at 90 bucks a pop the jonnyreds don't have this prob at least my any way ;D         thanks for any info
Dealer don't know? Call up Husky direct. Must be a reason why.I have an older 372,6-8 years old.
coxy
dealer told me I was tacking the drags down to far  and it was vibrating to much never heard that one before   but it doesn't bother my jonnyreds  and they are the new 2172s
treeslayer2003
put blue Loctite on the screws.
tacking the drags down to far? Meaning using the dogs to cut with?
husky fan 500
ur dealer said that u had the rakers filed down too far???  that would give a little more vibration as u know. is the muffler coming apart or coming loose?  if its loose use loctite if it comes apart id put a couple of tack welds on the seam between the halves
rakers,  :-[  Never heard them called drags. I guess I need to get off the hill more.
SawTroll
Quote from: thecfarm on October 26, 2013, 10:34:11 AM
Maybe you do, as it isn't that uncommon to call them drags... ;)
Information collector.
Full Chisel
I dunno who will agree on this and who not, but here it is. If you got them screws coming loose on J-Red or a Husky, and nothing else works, refit it with left hand threads.
Jed: Jethro, how's come they ain't no ice in Kali Forni-a?
Jethro: Don't look at me Uncle Jed. I didn't take it.
sharkey
I think your going to find whether left or right thread its the vibration that is causing the problems.  Red Loctite or buy longer bolts and safety wire it.  Bailey's has the aftermarket muffler on sale for $30.
http://www.baileysonline.com/Chainsaws/Chainsaw-Parts/Muffler-Exhaust/Husqvarna/Muffler-for-Husqvarna-Jonsered-362-390-2063-2186.axd
coxy
the bolts are not coming lose the muffler is splitting in half but not at the seem  or it blows a hole in the side by the bar  ???
JohnG28
That sounds like an interesting problem!  ???
sweetjetskier
I have 2.5 years of run time on a 372 x-torq and have not had any problems at all with the saw.
I always check fasteners when I clean up the saws after use though
Arborist, Horticulturist, Nursery and Turfgrass Professional with 27 years experience.
angelo c
Quote from: coxy on October 27, 2013, 10:09:50 AM
"Holy hoppers Batman !!!!"  Never head of that happening before. Any chance of posting a pic?
Man thats tough to wrap my brain around the exhaust pressures needed for that to happen coming from a small 2 stroke of any sort. Bad welds would have been my first thought but blasting out the side is wild.
wife,kids,dog,t-shirts to prove it
Coxy,what are you feeding that critter.??I would just weld a heavier patch inside the muffler where the burnthroughs occure.I think there are outher problems afoot here perhaps burning too hot or lean. Frank C.
coxy
Quote from: angelo c on October 28, 2013, 07:24:58 AM
sorry meant to say and blowing a hole after it splits  sorry
coxy
I run the same gas in the other saws and it doesn't bother them  was told it might be a bent crank ??? don't under stand how that could happen  but weird things happen to strange people :D going to try one more muffler if it cracks its dozer bait ;D
tlandrum
when you give up on it let me know and I can figure it out for you. I have all the needed parts to fix anything it could be.
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
husky fan 500
no no no dont make it dozer bait. there are aftermarket dual port mufflers out there that might be an option 4 u  or if ur anything like me take one of the old ones and make your own.  i just made one last wknd  i drilled a hole in the side  one half the dia of the oem hole there is a difference but not a great lot
