believe it or not, but..
Started by roghair, October 25, 2013, 05:50:30 PM
roghair
a few weeks ago was the first time I saw a sawmill in real life other than my own (home made) sawmill. Although I am fine with my sawmill, I was impressed with the smoothness and power of the LT70 that was demonstrating at a forest management seminar/event I attended.
http://www.youtube.com/watch?v=WKwAKw2J_t8
The event was organized at a very nice estate here in The Netherlands:
built a sawmill
Chuck White
They are definately a nice machine, but a little out of my reach  :-\ nice looking estate too!
Thanks for posting!
Nomad
     Roghair, what was he cutting?  Sure looks like he was taking it slow.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
customsawyer
I would have to agree with Nomad.
www.thecustomsawyer.com
5quarter
I think he had his blade on backwards... ;) :D
   Perhaps he only had a couple logs to demo on and needed to stretch out the sawing.
Blue Harbor Refinishing
Bandmill builders thinking about a hydraulic turner /clamp replay the first part of the video.The two plain clamp/turner works well and is very simple to build. LT-70 is sure a spoiler, I ran a new one for a couple of years, made it hard to drop back to my selfbuilt. Frank C.
roghair
He was cutting a douglas, and yes he was taking it slow at that moment. The surface of the boards were smooth as if they were planed (probably because he was so slow)
built a sawmill
Delawhere Jack
Everyone is impressed with a WoodMizer. It's the mill that loves you back!  smiley_love
Must admit I'm a bit jealous of the newer WM's with the two plane clamps, chain turners, vertical backstops, fancy computer setworks and all...... But then, what fun is it milling without the chance that you'll get your claw turner pinned under a heavy log with no support equipment to bail you out...  :o
I still move my OLD Mizer!  :-*
two-legged-sawmill
Hello,without a doubt a well built and engineer mill, great for the Guys that can afford them, going back to the old saying, still holds true today. " If wishes were Horses, Beggers could Ride!"
     The Forum is a great place for information, and I love it! However, as a newbe the biggest gripe I have is the comparisume that are posted! If a party can only aford a chainsaw to make lumber so be it, and if you can only afford a Hobbie mill, yes it will take you longer. the bunnie and the turtle proves the point! I think we should compare apples to apples and not run down a mill that is desgined to be flown into the bush with a light track. To larger Horse power and rugged tracks. Most coments slam bang the mills that $5k to the ones that upwards to $40k or more.  My Take Dan.
"There are no secrets to success. It is the results of preperation, hard work, and learning from failures"
Ga Mtn Man
Dan, I think your comments are without basis.  Most guys on the forum go out of their way not to make unfair comparisons of one type of mill to another.  Please give us some examples of someone, as you say, "slam bang the mills that $5k to the ones that upwards to $40k".
Nomad
   ???  Did I miss something?
Lucas DSM23-19
