Cedar Cookies
Started by POSTON WIDEHEAD, October 24, 2013, 07:41:39 PM
POSTON WIDEHEAD
I sawed a few Cedar cookies from an old dried log yesterday. MC in the center of the cookies are 11%.
I sanded a cookie down last night and added 3 legs for a foot stole.
In the picture, you see Poly that has just been brushed on the cookie.
Problem to me.....this wood is sucking up Poly F A S T ! I have put on 8 coats and it keeps soaking in.
How long will this go on before I can get a shiny finish? Is there something I can apply to seal the wood and THEN add more Poly.
Here is are pics just before I applied the first coat of Poly.
mmartone
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
goose63
don't know what you can put on it but I think it would look mighty good in front of my recliner  8) :snowball:
goose
thank you to all the vets
jueston
Axe Handle Hound
Glue size.  Mix ordinary white glue with water at about a 1:10 ratio, maybe a bit higher for something as porous as that cedar you're working on.  Brush it on, let it dry, and then sand lightly to smooth the surface.  If you sand aggressively you'll end up sanding off all your sealer and you'll likely melt the glue from the heat generated by the friction and clog up your sandpaper.   If you prefer stinky, smelly epoxy (I have a thing about epoxy) you could try smearing some across the face and then sand in a similar fashion when it cures, but it's likely going to require a lot of elbow grease to smooth out.
Sanding Sealer.  It should have gone on first, but I think that you will be OK between coats.   Next time, Sanding Sealer first.
If you sand it very fine, going thru the grits from 80 to 150 to 220, then buff with 0000 steel wool, that should do it.  More work, though.
downsouth
That cookie sure would have made a nice looking clock!
The stool looks good also.
Wick
That poly cookie stool looks great. But I'm in the market for some wide devil wood mantles.
Timber Harvester 30HT25
Lud
You might have used CA but I think the white glue wash was the most economical option. 8)
POSTON WIDEHEAD
Quote from: Wick on October 25, 2013, 04:11:50 PM
...... But I'm in the market for some wide devil wood mantles.
I hear ya Wick. I picked up on ya. You been doing some reading.  smiley_thumbsup
POSTON WIDEHEAD
Quote from: Magicman on October 24, 2013, 10:30:31 PM
Took your advice Magic.
I finished up ANOTHER stool this afternoon.
After completing the sanding on the Cedar cookie, I applied 2 coats in 2 hours of "CABOT" sanding sealer. I'm applying Poly now without any problems.
That sanding sealer cured the problem of that thirsty, Poly drinking Cookie.  smiley_thumbsup
lowpolyjoe
Wow... beautiful color  :o
Wick
 :D Can't get nothing by you  whiteflag_smiley
grweldon
In case you might want to try it, shellac is also a sealer and any topcoat can be sprayed over it.  The nice thing about it is that you can thin it to almost any consistance (with denatured alcohol) and it will still work!
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
Axe Handle Hound
Very true provided it's dewaxed shellac.  The amber shellac typically found at home centers is not dewaxed and topcoats won't bond properly to it.
grweldon
Yep... forgot about that...  I usually use blonde...
m wood
Oh David, seems we got the poly thirst solved.  Any chance of a closer look at the legs and under side?  I see tenons coming clear through.  They look like some "cool" crookedy sticks under there.
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
epiphoneprs
Would you mind telling me how you attach those legs?
POSTON WIDEHEAD
Quote from: epiphoneprs on January 08, 2014, 12:05:45 AM
Be glad to.
I first turn the seat upside down.
I then use GORILLA GLUE (the gooey stuff) to glue each leg in place.
Later after the glue dries......I will angle 2 small wood screws (about 3 inches long) through the side of each leg in to the bottom of the seat. This just firmly holds each leg in place and gives more stability.
I then turn the stool up right and pre-drill holes over each leg through the seat only. I want to counter sink the bolt heads.
Then I just screw the lag bolts through the seat down into each leg.
I make sure the pre-drilled hole through the seat is a little larger that the lag bolt so it won't crack the Cedar Cookie.
When this is done, just plug each hole where the bolt went in and sand it down flush.
If need be, you can also pre-drill down into the leg also if you think your leg may split also.
Then take the stool to the mill.....turn it upside down and clamp it.....then saw the legs off flush.
The stool will set true then.
grweldon
Those legs aren't going ANYWHERE!  Very nice!
Andy White
David
That is some really good looking Cedar Cookies!! I gotta find me some of that to attack! I also like your freestyle methods. I have trouble envisioning anything that is not square and flat. Outstanding job!    Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
For a man who has broomsedge growing on his fireplace mantle, he does pretty good.
POSTON WIDEHEAD
Quote from: WDH on January 08, 2014, 09:16:43 PM
The wife said I used to have broom sedge on my face too.  :D
I have some stuff that will kill it.  I could send you some.
