562 prob solved...i hope
Started by MEloggah, October 16, 2013, 01:32:24 PM
MEloggah
i went to my local dealer a month ago to add another lughter weight choppin saw to the fleet. they didnt have any 562s and werent getting anymore from husky untill they solved the issue. the gasket was leaking bar/chain oil into the crank case and cookin them. they called and said they just recieved 10 from husky with the correct gasket. gona pick it up tonight and cut a few tractor traileloads the next few days see how she goes...fingers crossed..
meanwhile my other one is getting split and the right gasket installed before it fails. i know of 4 that have..
nmurph
I don't think it was the gasket that was the problem but rather the case bolts were backing out. H updated the 562 case bolts by replacing them with the case bolts from a 357...and it was done pretty early on in production.
SawTroll
Quote from: nmurph on October 16, 2013, 09:40:44 PM
I agree, but wasn't it the cylinder bolts from the 357xp? My memory may of course be off..... ;D
Information collector.
nmurph
Quote from: SawTroll on October 16, 2013, 09:54:02 PM
Wasn't it the cylinder bolts from the 357xp? My memory may of course be off..... ;D
That may be right as it was my first thought. You know you first instinct is more likely than not to be the correct choice!!
SawTroll
Quote from: nmurph on October 16, 2013, 09:56:16 PM
True, and I checked the SB in the meantime - it was (is really) the 357xp cylinder bolts, that apparently provides more friction than the bolts originally used.  ;D
MEloggah
well that could be also but it WAS also a gasket issue. they had about a dozen they were replacing. pretty sig diff in the two gaskets frpm the orig to the new ones husky sent them
SawTroll
Quote from: MEloggah on October 16, 2013, 10:17:11 PM
Surely, as loose bolts caused damage to the gasket, or at least it could have done so.  ;)
nmurph
I haven't seen any service bulletins regarding replacement of the case gasket with an updated version (as there would be), but there is one for the change to the case bolts that are used.
SawTroll
Quote from: nmurph on October 17, 2013, 07:52:41 AM
True, as far as I know - but I don't always know it all...... ;D.
nmurph
Quote from: SawTroll on October 17, 2013, 04:13:42 PM
Stop being so modest!!!
Joe Kidd
Some of the earlier bolts failed to have the black oxide coating which imparted much more friction than the slick ones. I've not seen a gasket TSB.
Husq 545
Husq 562XP
Jred 2188
MEloggah
 well....all i can say is ehat my dealer showed me.  we have bought all our saws thee for the ladt 30 yrs and they have always been good to us and seem to know what they are doing. i really like the favt that they freeze all their saws. in any event hopfully we are good to go. cut a load of hemlock today. no hiccups.
SawTroll
If the gaskets were defective on a limited batch of saws (or suspected to be so), I guess there could be a "callback" on those saws, without it resulting in a SB....
MEloggah,I forgot what part of Maine you are from. What dealer are you using?
nmurph
Quote from: MEloggah on October 17, 2013, 06:11:35 PM
What's different about the "new" case gasket?
What is "freezing" a saw?
nhlogga
Your dealer is fantastic. Too bad their top saw tech retired. He taught me alot.
Jonsered 2260
Husky 562xp
MEloggah
im in southern oxford county on the nh border.  im assuming u figured out my dealer when i said they freeze them. they freeze alot of stuff actually. chokers, files, hooks, bars etc.
windy ridge is the dealer we have used for long ad i can remember.
MEloggah
What is your understanding of the "freeze" treatment?
MEloggah
Joe Kidd
I leave all my OPE's in the shed all winter for a cryogenic soaking.  say_what  To cryo an entire saw is gimmick IMO, however some metal parts MAY benefit. It's very very far from an acceptable practice which leads me to doubt it's effectiveness as a saw treatment.
Husq 545
Husq 562XP
Jred 2188
MEloggah
gpod for you.
im a 5th gen logger and can tell u ive seen a huge diff in the durability of chrirogenic over the ladt 20yrs. i suppose ypur shed doesnt get cold enough hillbilly
Joe Kidd
 :laugh: You're probably right!  smiley_beertoast
Husq 545
Husq 562XP
Jred 2188
MEloggah
lol sry the redds apple gettin the best of me . {inappropriate language edited by admins} good >:(
sharkey
This is the first time Ive heard of freezing a saw.  What does this do for it?
chet
My saws git da freeze treatment every winter, weather I or da saws want it.   :D
