Felling Diagrams
Started by John Vander, October 09, 2013, 07:29:22 PM
John Vander
Here are some diagrams for safe felling.
AROUND THE BACK CUT
Use for trees where bar length is insufficient for tree diameter.
Bore in on bad side and prepare hinge. Cut around the back and insert wedge. Continue the cut and finish on good side.
Tree and saw accidents nullify years of forestry experience.
If we are looking down on the stump, no quarrel with the technique but am wondering why the saw is upside down? Cutting on the top of the bar pushing the saw out of the cut.  ??  Just curious.
John Vander
BORE CUT for SMALL LEANER
Bore in on the bad side. Make sure saw passes through the other side of the tree. Be careful not to cut into hinge space on the opposite side. Open the cut and prepare hinge. Prepare holding strap. Cut strap for release. Cut strap about 1 inch below bore cut from the back.
clww
I was wondering the same thing, beenthere.
Many Stihl Saws-16"-60"
18-Wheeler Driver
John Vander
Sorry about the pic of the saw. It was in my computer and I used it to make the pics. It's just to illustrate where the saw goes. Being a faller you know in what position the saw is. Sorry about the bad pic. ;D
John Vander
I didn't have a pic of the other side of the saw! :D
And for the small leaner, I use the bore cut a lot, but I usually set a wedge or two in the back cut before knocking off the holding wood. Just in case the lean isn't figured just right and the wedges save you from being caught real tight, real quick if it sets back at all.
John Vander
BORE CUT for BIG HEAVY LEANER
Bore in and cut out to the back on the bad side. Bore in on the opposite side and prepare the strap. Cut strap for release.
John Vander
beenthere, yeah, I do the same too. It's a good safety precaution. Sorry I didn't add it here into the diagram. Good point.
John Vander
OVERLAP CUT
Do a back cut covering 60% of the back of the tree. Insert wedge. Repeat same cut on safe side overlapping previous cut (bottom). Insert wedge. Drive in wedges to fell. Use for small straight trees where lean is hard to determine.
John Vander
SWING CUT
Bore in on the safe side and prepare hinge. This is a good technique where the bad side is really unsafe on a leaner or where insufficient work space makes it hard to get to the other side of the tree. Once the bore is completed and the the hinge is in place, pull the saw back on the dogs to prepare a holding strap. Cut strap for release. A wedge can be added on the opposite side of the strap, but make sure the bar will pass the wedge safely.
John Vander
TONGUE & GROOVE
Shallow scarf. Bore into the front of the scarf to the back. Make sufficient room for the wedge to pass through without cutting away too much wood where hinges will be made. Insert wedge and drive in. Cut on sides above bore cut to prepare proper stump shot. Drive in wedge to fell. Use for small trees with slight back lean.
John Vander
QUARTER CUT
Bore in on bad side and cut around the back, making sufficient wedge space. Insert wedge. Complete hinge by cutting below the wedge as not to hit it. Drive in wedge and fell. Use for small trees with slight back lean.
John Vander
DANISH PIE CUT
Bore in on bad side and prepare hinge. Cut away back to prepare space for wedge. Insert wedge and cut remaining holding wood from underneath. Drive in wedge and fell. Useful for trees with slight back lean.
John Vander
WEDGES
A faller's best friends. Inserting wedge to the side will improve lift. Use wedge with tapered scarf for side leaners or adding lift to a swing cut.
John Vander
T-CUT
On large leaners, the saw is put at the side of the tree and pulled back on the dogs. On smaller tree the cut can be performed the same as with the cuts made on a tongue & groove cut. Cut back strap (in the shape of a bar) to fell.
John Vander
SIDE BIND
When a felled tree is lodged between standing trees, side bind is present. This technique deals with safely releasing the bind so that the felled tree opens up safely.
P: position
C: compression
T: tension
Stand on the compression side and make two "V" cuts that meet. Cut over the top drawing the saw to where you are. Tension will gradually be released as the logs slowly open. The yellow arrow on the bottom pic shows the path of the saw. It is advised NOT to stand directy behind the saw, but at the left of the saw.
John Vander
RELEASING ROOTPLATE
P: position
T: tension
C: compression
Cut over the top and draw saw into wood about one fourth of the way. Bore in from the side but DO NOT cut the top yet. Cut downward and let the saw exit the bottom, leaving a small holding strap. This small strap in not cut, but functions as a "jump stopper" to help the log release from the stump slowly. The final cut is from above to release, made slightly off to the right to create a shoulder. The shoulder protects the bar from getting knocked up as the log opens.
John Vander
CENTRE SCARF
Large trees can be scarfed in this manner to reduce holding wood. Make sure to add wood to hinges in order to compensate for hingewood lost due to scarfing. Back cut is made standard above scarfing to create stump shot. Good for cutting trees where the bar length is insufficient. The back cut is made by cutting around the back. Bore in and move the saw around to the other side.
John Vander
DEFECT TREE
A tree with a defect like rot in the middle needs to be felled carefully. Scarf a but deeper than usual. Cut around the back from bad side. Make sure hinge is prepare in sound wood. Cut away rot to expose sound wood so that hinge can be made accurately. If tree seems unsound, bind up the tree with rope prior to cutting. The rope will help to hold the tree together during the fall. Where the tree has no crown, reduce stump shot.
mesquite buckeye
John Vander
DEFECT TREE with TAPERED HINGE & STRAP (SIDE LEANER)
Prepare a tapered hinge in sound wood. Bore in on both sides to prepare hinge. Cut back to prepare strap. The grey arrow shows the direction of lean. Cut strap to release.
John Vander
WING CUTS
Add wing cuts to the hinge to reduce root pull on softwood trees. Not recommended for hardwoods. Useful where scarf doesn't properly cover the face of the tree.
John Vander
ENLARGING SCARF
Where bar length is insufficient, a large tree can be scarfed in two steps.
luvmexfood
I would like to thank you for taking the time to develop and post these diagrams. Never hurts to learn something.
Give me a new saw chain and I can find you a rock in a heartbeat.
