Curved quarter sawn white oak bar rail
Started by GAmillworker, October 07, 2013, 10:59:47 PM
GAmillworker
This is what we built in my shop last week.  I cut pieces out on cnc first.  Then glued, stacked, and clamped them.  It took almost as long to build jig to hold them to run on the shaper.  I used several different sized bearings to run the jig across the shaper.  The overall hight is 6" starting thikness was 1-3/4".  the jigs in the first pics with the gussets did not work we had to build it with square blocks with template on bottom and plywood support on the top with handles between.  The feeder was just used as a safety to have something between me and the cutter.
Thank the Lord for second chances
mesquite buckeye
pasbuild
If it can't be nailed or glued then screw it
m wood
WOW, well done.  commercial or private customer?
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Look at all that lumber in the rafters  ;D.  Daniel, that is a very well done piece.
GAmillworker
Thanks guys
m wood,
It is a commercial piece.  It is going in a restaurant bar in Charlot NC the Marshal free house.
Just noticed that it is upside down in all the pics.  the french curve is actually the top with the bead and cove on the bottom.
I rotated and cropped second pic to show the way it goes.  it is datoed in the back to receive 3/4" counter top
Leigh Family Farm
There are no problems; only solutions we haven't found yet.
Axe Handle Hound
Kilgrosh took the words out of my mouth.  That is very impressive work indeed.
drobertson
Yep, next level for sure, nice!    david
I do hope to see it with a stain on it and in place,please?  ;D A very nice job.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Lud
Quality work!!  Goin' for a hard poly finish?
Lud
So the bar is upside down in the pic?   ???
Then the cove with a sharp edge is goin' under where it will meet the thighs of desirable  people!!!!...........Heavens Forfend! .  Best champher away, my friend.
Perhaps you haven't reviewed the aesthetic . ethical  perspectives of bar surface and sub surface /customer interaction.  Gotta make it nice!   I'd require mockups and extensive testing.  Might be worth recording on video! :D :D :D :D
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
