Blade detective
Started by Larry, September 09, 2013, 09:19:54 PM
Larry
A while back my mill had a match up with an oversize oak.  The mill lost and while getting the band out of the cut it came off the wheels.  Next cut was rough so I figured I had knocked the set out of a couple of teeth.
When I re-set the band this afternoon all the teeth were near perfect so I knew that wasn't causing the rough cut.  When setting the teeth looked a bit dull but not bad.  I did notice the band was a little tight going through the setter at one point.
I laid the band on the floor where I could look down at it.  Instead of round there was one spot that had a very slight ellipse.  Closer examination showed at the apogee of the ellipse there was a very slight twist in the band.  I would have never seen the twist if it hadn't been laying flat on the floor but I did feel it in the setter.  Normally I would have thought a piece of crud on the band caused the tightness.  This twist was what was causing the roughness in the cut and also the reason the band felt tight going through the setter at one point.  The band might be ok for a nail log buts that's it.
If I know the band is sharp and set good but won't cut the first thing I do is lay it on a flat floor.  Sometimes I've seen them not lay flat or like today discovered a twist.  I've even had a couple of new bands that showed a problem from the factory.  Maybe the forklift guy punched em.
Just thought a tip that might help somebody.
I put a blade on today and immediately recognized it.  It must be warped or something because it causes the sawmill to actually vibrate while sawing.  I do not plan to loose it again.  It either gets fixed or trashed.
Peter Drouin
You will feel it when you coil it up too . It will want to open on you
A&P saw Mill LLC.
License NH softwood grader.
drobertson
this is just my humble opinion, and of course I am a rookie, so please take this with a grain of salt, but I have found with the few blades I have been through,  even though there is only .003 difference between the 042's and 045's on most blade manufacturers, the wmz's are a different tool steel, a good one! just tougher than nails through the whole blade, and often times harder and a bit brittle for my operation.  I have found when using wmz's, feed hard and fast, and take what they give, and it is good while it last.  wmz's are just to brittle for my mill, and it is probably me and my dumb way of sawing.  I like blades that are as dumb as me and just keep on sawing, even if it's break time,   kinda dumb concept, but I never have been accused of being that sharp anyway,,  david
Good info Larry,twists and kinks are something that's hard to take out of a band it renders them usable but less than prime.Catching the back of the band on gigback or trying to back out is the usual cause to push a band off its wheels.If the wrong lever is hit wile in a cut it has much the same effect.If you have clearance its good to have something soft inside the bandwheel covers to save the teeth when a band comes off the wheels. Frank C.
giant splinter
Larry,
Thanks for the heads up, I have noticed that every once in a while when I put a fresh blade on the mill something just does not seem right. The first few times I noticed a slight vibration and or a difference in the sounds that where coming from the power head and band wheels I suspected that I was responsible, after shutting down and carefully inspecting things I could not find anything out of alignment or adjustment. The mill was new and although I had been through Wood-Mizers 8 hour training course at the Oregon branch before taking delivery of my mill I kept thinking I may have missed something or may be doing something wrong, I was in a transition period from an old Frick 00 to the LT40HD and just was not that dialed in on the orange bandsaw mill, I don't sharpen or set my own bands and depend on Wood-Mizer re-sharp to keep me in fresh saw blades.
Over the past two years I have had a few bands that did not seem right from the first cut and they where taken right back off and are now in a box and awaiting a suspect metal log to show up, interestingly enough the replacement band that took over where the suspect band left off did a fine job so who knows whats going on there, I have taken a few of the fresh bands that seemed short of acceptable to re-sharp and asked what they thought, the response is on par with the bands ( short of acceptable ) and may be something that just happens during shipping or handling ...... after the same band came out of re-sharp it cut fine. Seems like the old saying " you win a few, you lose a few and some get rained out " might apply in this case.
roll with it
hackberry jake
I have noticed "wobbly" bands right out of the box before. I blamed it on the band not being welded perfectly straight.
sawmillhand
Good thread because I thought I was crazy I had a new blade right out the box do the same thing to me. Vibrated the mill and I actually seen it start diving while I was sawing. Put new blade on all was well.
1990 woodmizer LT40 Hyd  2004 Ford F350 Flatbed. Plenty of tractors.
You just know standing at a bench all day welding bands is a boring job and mistakes slip through. Frank C.
I would expect the welding process to be pretty straight forward with no room for human error getting it straight, square, and a near-perfect weld. i.e automated and not done by hand.
Could be wrong, but auto is what I'd suspect from any blade maker.
Does bandmiller know different?
Larry
I think there may be a big difference in the equipment/automation used.  When I get a WM band now days its hard to spot the weld because its so good.  Other band sources and the grind on the weld stands out like a sore thumb.
Makes me think some welds may be better than other welds. :D
WM sent me a selection of videos when I sent my Personal Best entry and one of them shows welding a band.  It is all enclosed and automated.
hackberry jake
There are many sources for bands. Each one likley has a slightly different set up.
ladylake
 Bandsaw welds are all ground as the blade is fused leaving a little hump on both sides , WM must use finer sandpaper for the final grinding.  I'd rather have a weld I can find easy as I start both sharpening and setter at the weld.   Steve
I have seen videos of band welding,the band stock comes in large rolls its pulled out on a long table cut and welded by an automated welder then the joint ground smooth.I would be very surprised if WM did not have the process completely automated.I have welded many bandsaw loops for a metal cutting bandsaw,not hard if you take care in your work. Welding done butt weld with a resistance welder for the purpose not by hand. Frank C.
Quote from: Larry on September 10, 2013, 09:45:24 PMWhen I get a WM band now days its hard to spot the weld because its so good.
Larry, I think that it is your eyes.    ;)  The WM welds are easily seen.   :D
GeneWengert-WoodDoc
On Friday morning at the Paul Bunyan Show in eastern Ohio, October 4, we are having a seminar on band saws...W-M is one of the presenters, along with Lenox and me.  It is 1-1/2 hours.  Q&A is part of the seminar too.
MRowsh
According to what I have been finding out about the process of making band saw blades,  there is two methods;
1. Punched out saw blades
2. Grind out saw blades
Which is better?  Anyone has any hands on experience to share?
LogMaster LM2 with Kubota V1305 Diesel conversion.
There is a price for everything in life!!!  No free lunches!
Retired US Army.
ladylake
I think all are punched out, some are ground after punching.    Steve
What I would say too...  punched and then ground.
MRowsh
No, not all punched and then grounded.  If I am not mistaken, some are computer controlled grounded, from start.
punched and sharpened introduces some stress to the metal.
Retired US Army.
MRowsh
Are you talking just about the sawmill bands, or including all bands for band saws?
What is your source for the info you are finding? It would be interesting to learn more about it.
MRowsh
I remember from when I was stationed in Germany, one of my German friends from shooting team in our Gun Club was working for a company that were in all sort of saw blade manufacturing. I got a tour of the factory too. Very impressive operation. I did enjoy watching their tempering process and it was very educational.  That was another deciding factor on my decision for what I have placed my order for LM2.  According to what I read, that is how they produce their saw blades.
After I get my saw mill, then I can test their blades compared to others and verify their claim.
Retired US Army.
ladylake
Quote from: MRowsh on September 11, 2013, 12:16:51 PM
  I cant imagine them grinding out the whole gullet, laser cutting might be another option.   I really don't think punching stresses a blade as I run Simonds that I know are punched and get 20 sharpening's out of quite a few.  Steve
Theirs a lot of hype spread by band suppliers to convince you that their product is best.There is little difference between the name brand bands,theirs no majic except sharp and well set and close to right hook.Anyone who has worked manufacturing would know the most efficient way to shape bands would be punch then sharpen on a grinder. Frank C.
