clean saw
Started by skeetsman, August 28, 2013, 11:10:34 PM
skeetsman
getting ready to tear down a saw have always used brake cleaner. someone told me carb/choke cleaner was better. never had a problem. any suggestions
cs8000, 702evl, 365sp, 32 ton splitter 350husk, cs6700
I'd consider cleaning with "Simple Green". It cleans up my saw real well... including the carbon from the exhaust.
Skeets,brake clean is a good product but be carefull it will desolve some plastics.The new eco-friendly brake clean is close to worthless.The good old chlorinated stuff be sure you don't put it in with drain oil it will turn it all into hazardous waste.Your probably better off with the auto store spray cans you can hose off. Frank C.
jd2007
Usually I'll use an air compressor to take off as much dirt & crud as I can then spray everything down with Purple Power degreaser & let it soak for a bit then hose it off then use air compressor again to dry everything off.  Some lucky people have access to a parts wash which would be great too.
Stihl 029S/039, MS280, MS250
Craftsman 4218
AKDoug
Non-Cholorinated CRC Brakleen is perfect for saws. It's all I use in my shop. It will not hurt the plastic and washes off bar oil and 2-stroke oil instantly.
A little tip the old chlorinated brake clean is none outher than dry cleaning solvent  if you track grease on mommys carpet it will save the day,just be sure to open the window. Frank C.
Pullinchips
Quote from: jd2007 on September 02, 2013, 07:42:45 PM
I do this as well
Resident Forester
US Army Corps of Engineers: Savannah District
Clemson Forestry Grad 2004
MFR Clemson University 2006
Stihl MS 390
AdkStihl
Yup.
Just make sure not to get water in the exhaust or intake
J.Miller Photography
