Cracking in the gullet - and when to change a blade based on hyd pressure?
Started by acrosteve, August 12, 2013, 04:48:23 PM
acrosteve
I saw the thread about leaving the blade tension on overnight.  I will admit that sometimes I have forgotten to release it when I finished sawing.
I also have probably used a blade much past where it needed resharpened.  I have thought that that would also stress the blade to the point of cracking.
But recently, I have started watching the pressure gage on my carriage feed more than I have been watching the actual carriage.  It seems that in oak, a new blade starts out at about 600psi, and as the blade dulls, the pressure climbs upwards of 700.  Consistently above 800 and the blade comes off.
My B-20 has a pressure gage on the blade tension also.  I run it around 1,000 psi.
Obviously cracking in the gullet excludes it from being sharpened - therefore I want to avoid having it happen.
My question is, what are the causes of the gullet cracking?
Timberking B-20
Larry
My old mill had electric feed.  As the band dulled I had to increase speed...in other words turned up the rheostat.  On my TK2000 it doesn't have a gauge and it's impossible to tell from the feed dial, but I'm sure I have to turn up the feed as the band dulls on it to.
If your band is coming off I would suspect a problem even though you are feeding with more power.
Cracking in the gullets can come from a variety of reasons.  Band running to far from the roller flange, bad bearings, worn belt (if on steel worn wheel), and probably other reasons I haven't experienced and don't want to.
redprospector
In my experience, trying to cut with a dull blade will cause cracking in the gullet.
You're way ahead of the game if you'll change out blades before it really gets dull.
Andy
ladylake
Quote from: Larry on August 12, 2013, 05:02:21 PM
Larry    A band running to far from the flange will crack in the back of the blade, a band running too close to the flange will bend around the guide wheel causing it to crack in the gullet. I set the flange almost 1/4" behind the back of the blade with real good results.  On time the flange got real close to the back of the blade and broke about 6 almost new blades real fast, I pay attention to that now.   Steve
Tom the Sawyer
Larry,
"Consistently above 800 and the blade comes off."
I think he meant that once the pressure got up to 800 he would pull the blade to resharpen, not that it came off the rollers.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Brian_Rhoad
Not grinding enough in the gullet when sharpening will cause cracks.
LeeB
Not grinding enough won't actually cause cracks, it will however allow existing micro cracks to become big cracks.
acrosteve
Quote from: Tom the Sawyer on August 12, 2013, 07:57:37 PM
Larry,
Correct.
Timberking B-20
