Author Topic: Norse winch broke.  (Read 1670 times)
Offline timeout
Norse winch broke.
« on: August 12, 2013, 04:23:25 pm »
 I have destroyed the pulley in the block that swivels on the top of a 2500 Norse winch. Labonville no longer has that part available. It is part number 251029. I have done some research for a replacement, but so far come up empty. Does anybody know where I can find a rugged 5" diameter pulley, and bearing that will go on a 3/4" bolt.?
Apparently, my stressing it with red oak was too much for it. I will try to be gentler in the future.
"Another day closer to heaven."
Offline treefarm
  • My other wife
Re: Norse winch broke.
« Reply #1 on: August 12, 2013, 06:41:23 pm »
Do a search for McMaster Carr. They're an industrial supply place in NJ, and have darn near anything you could need, made out of any material available. and their shipping usually has it there, UPS, the next day. It's like Graingers on steroids. Good luck!
Treefarm
Offline thecfarm
« Reply #2 on: August 12, 2013, 09:31:32 pm »
That is too bad. I myself never cared for any of the winches with the swivel pulley on top. I have a Norse,the one with the hinged butt plate. I have no idea the model,looks like the 450 that is out now.
Offline Brian_Rhoad
« Reply #3 on: August 12, 2013, 11:56:55 pm »
Offline grassfed
    • Kingdom Hill Farm
« Reply #4 on: August 13, 2013, 09:59:09 am »
Do a web search for sheave and add the diameter and cable size you need. you should be able to use steel to make up the rest. I tried a search for 4"x 1/2 sheave and came up with this
http://www.esheaves.com/
Mike
Offline grassfed
    • Kingdom Hill Farm
« Reply #5 on: August 13, 2013, 10:16:10 am »
Here is one from grainger that you may be able to use...
http://www.grainger.com/Grainger/Sheave-5RTF0
Mike
Offline timeout
« Reply #6 on: August 15, 2013, 07:54:04 pm »
 Update on Norse winch problem. Took all the advice and researched and couldn't find a close enough replacement that would work without some modification. Ended up at Motion Industries and set the pulley on the counter. The gentleman was able to find a roller bearing that would fit inside the pulley and slide on the bolt. I made some spacers out of flattened out lock washers and put it back together. This is probably a temporary fix. I'm using it again , and keeping a closer eye on the pulley. I am still looking for a replacement.
Offline North River Energy
« Reply #7 on: August 15, 2013, 10:34:53 pm »
Would be interested to see the damaged part.  Don't suppose you took a photo?
Offline timeout
« Reply #8 on: August 16, 2013, 07:40:14 am »
No photo. Steel pulley that is approximately 5" in diameter. 3/4" in width. Has a bearing that goes on a bolt that is a little over 3/4". These measurements are close ,because this part is metric.Pulley cable groove is getting very thin on sidewalls that is why I am looking for a replacement. What do other brand winches use for top swivel pulley blocks?
« Reply #9 on: August 16, 2013, 08:27:25 am »
This turned up on a search for 'cable sheave'
http://bearequipment.com/product_sheaves.html
Quick chart does not show a direct replacement based on your description, but they may have something not listed.
I'd be tempted to uprate to something more durable, if you have the means of altering the sheave carrier.
Offline Tom_Averwater
  • Semi- retired Carpenter
« Reply #10 on: August 20, 2013, 05:34:30 am »
Have one made at a machine shop .
He who dies with the most toys wins .
