garage door springs
Started by wscott, July 28, 2013, 09:02:49 PM
wscott
someone posted how to lift sawhead on wm using garage door springs. unable to find post. need help. thanks in advance.
wscott
You should always marry a ugly girl, when she leaves you, you want feel so bad.
drobertson
I searched as well to try and help, pineywoods has added a spring in the mast to pull the head back up, there are some mods, but not to difficult if I remember right, surely he will get on, or someone else, a few have done it, and it seems to work real good, it is on here somewhere I know,  hang in there, for a day or so, it will turn out for sure,  david
pineywoods
pineywoods,strikes again.  ;D
The idea of a spring head assist lift is a good one but as stated the spring should be caged ether in a plastic pipe or with a cable in the middle.If you have space restraints you can use a shorter stronger spring with a pulley on the end,cable goes through the pulley and back to the top and fastened.That will give you two inches of travel per one inch spring movement.If you swap a hydraulic cylinder for the spring you have my head lift system.Some down weight is good for stability,don't use too much spring. Frank C.
