Circular mill help (wooden pulleys)
Started by mikes47jeep, July 21, 2013, 06:12:15 PM
mikes47jeep
hi all
i have an Ireland No.2 left hand mill that I've been rebuilding,
i need to make a new friction wheel, for my feedworks drive
and my issue is i cant figure out what type of wood it was made from, too rotted to ID
I'm thinking oak???? maple??? ash??
any advice helps
regards
Mike
Ireland No.2 Left Hand Sawmill 48" blade
Probably any hardwood would make a good replacement, but I'd start with white oak if available.
Can you post a pic of what is left of it now?
Mike theirs a number of things you can make the friction feed pulley out of.Probibly yours is a sandwich of wooden discs.I rebuild the friction feed on my Chase with discs cut from old rubber/fabric belting.Clamped them togather with the through bolts and trued it up on a lathe with a sharp bit.Leather or even Masonite discs can be used too.If the shaft is a standard size those old compressed paper pulleys will work they put on tractors. Frank C.
loggah
A lot of old timers around here make frictions out of masonite sandwiched together. Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
