Thinking I should've said "no"?
Started by drobertson, July 12, 2013, 04:03:36 PM
drobertson
I got a call today from an ole customer, the last job was a large chinquapin oak, turned out great, this one is two 12' 30"+ hickory's, my last episode with large hickory did not work out so good, I have cut smaller ones ok, but these big ones can be a bear, didn't have much else to report on so I thought I would share the day, I said bring them, with warnings of wavy boards, he said fine, he just hates to see the old majestic logs go to the burn pile,  sure hope the 40 and me is up to the challenge,   david
BBTom
Do you have your 4° .055 blades all sharp and ready to go?  Sounds like you need them.
drobertson
No 4's, but plenty of sharp ones, I do have one 1-1/2 055, never used it, might be a good thought, thanks for the reminder BB,  david
Dan_Shade
I've Had Good Luck With 4 Degree Blades In Hickory
lots of dull bands and chains
drobertson
thanks Dan for the post, I have no 4's, have you cut much hickory?  and I have to say, I try not to rely on luck, although at times its better to be lucky than good ;D  david
Dan_Shade
I've Cut Enough To Know It's A Pain In The Rear :)
drobertson
I hear ya, man, just don't seem right does it, such a nice wood, smell great, just so much heat, unbelievable,  david
ladylake
Break those big cants down to a smaller size before making them into boards, I do that with spruce which saws good under 12" and not so good much over 14".   Steve
customsawyer
When cutting hickory I get by best when I run the lube full blast.
www.thecustomsawyer.com
YellowHammer
Quote from: BBTom on July 12, 2013, 04:12:05 PM
smiley_thumbsup smiley_thumbsup
I cut a fair amount of hickory, this is definately the blade of choice with lots of blade tension and oil emulsion based lubricant. (I use cotton picker spindle cleaner)
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
clww
I seem to recall reading on here that Hickory is the  smiley_devil
Many Stihl Saws-16"-60"
18-Wheeler Driver
drobertson
thanks guys! will be two logs, I tried the spitting into cants on the last go around, didn't make it through the log, but was a bit off on alignment then, not much but enough to cause havoc, full flood will be in order, and a good test for the Cook's super sharps, last case scenario, 1-1/2, 055 wmz, 1-1/8 pitch, alligator looking band for sure, I will put it on if need be,  still cant figure out hickory, why does it have to be so bad?  david
Peter Drouin
I don't cut a lot but my 7s cut it just find. and if your blade gets hot its dull :)
A&P saw Mill LLC.
License NH softwood grader.
Quote from: customsawyer on July 12, 2013, 06:38:59 PM
When cutting hickory, I get by best by NOT CUTTING HICKORY  :D :D.
POSTON WIDEHEAD
Quote from: WDH on July 12, 2013, 09:56:39 PM
say_what
drobertson
so its settled then, hickory is a pain in the rear, heard it for years, just a shame, I will do it, no time like the present.  david
5quarter
Hickory will separate the men from the boys. As my wife is fond of telling me, suck it up buttercup.  ;)
Blue Harbor Refinishing
captain_crunch
Beings it has been used for handles for past 100 years maybe we need to look back and see how oldtimers done it
cptn
Likely with circle mills  ;)
Satamax
David. The old timers here used to cut, hard to cut woods,  using diesel/home heatine fuel as a lubricant. Never heard of it done to a narow band, with ruber banded wheels. But you never know, it might be worth a try.
YellowHammer
If the wood is still green and wet, that will make it much easier, if its dry, it will be more fun :D but your saw will get er done.
Keep the blade tension up, almost pegged,  into the white and watch it like a hawk.   Also, if its a shagbarks, stay clear of the downstream side of the debarker, occasionally it will throw the scales of bark at a pretty good clip.
Hickory is some real pretty wood, it will be worth it when you get it done.(probably) :D :D
YH
YellowHammerisms:
dboyt
So... you're going from cutting sassafras to hickory?  That's going to be a shock to your mill.  Hickory degrades quickly and is more prone to powderpost beetles than any other species I know of (except maybe honeylocust).  Get it in the kiln QUICK!
rooster 58
   Good time to try the turbo blade ;)
vfauto
??? I have a large Shagbark Hickory to mill. What are the most common uses and what sizes do you suggest I mill for stock. :P
Thanks Frank
The definition of insanity is to do the same things over and over and expect a different result!
drobertson
Not sure really, this will be cut 1-1/8 random width, he just hated to so it go to waste, many folks make kitchen cabinets using hickory, and some flooring,  I guess it all depends on what you want,  david
