cleaning pine pitch
Started by anchorhd, July 10, 2013, 09:30:50 PM
anchorhd
i have been using my mx34 on some northeastern pine that I have a lot of on the property. i am having a problem with the pine pitch sticking to the mill and my clothes.
Anyone have solutions for the sappy substance?
Reg
northern pine? you're in upstate NY.I use to cut eastern white pine for logs. meaning I was logging white pine. I use to come home and wash my clothes with Tide,the powder,in cold water. worked for me. I would wash my clothes as soon as I got home.
5quarter
Reg...I'm from your neck of the woods. wherebouts are you at in WNY?
Blue Harbor Refinishing
Chuck White
Welcome to the Forestry Forum, Reg.
JSNH
Gojo hand cleaner. Do not get your clothes or you wet first. Rub it onto the area with the pitch, hands, clothes even hair then wash. Works better than gas.
Mineral Spirits/Paint Thinner should take care of it.
Barney II
Lacquer thinner will take off sap off without a doubt---don't put it in the wash tho ;D ;D ;D ;D ;D  I use it to clean sap off everything.  I use it to clean my car after sitting under the many white pines in my yard---does not affect the finish.  Lacquer is the only thing that I have found that will clean it up right now.
Ya never know
Woodmizer  1985 lt30
Barney II
That is lacquer thinner---not just lacquer as in the last sentence above---sorry ::) ::) ::) ::)
Ya never know
Woodmizer  1985 lt30
PC-Urban-Sawyer
Quote from: Barney II on July 11, 2013, 09:28:16 AM
Barney,
You can edit your previous posts. Just click on the Edit link in the upper right hand corner of the specific comment block.
Herb
Yes on the Go Jo too. I keep some out back by the outdoor faucet. That takes off one layer before I come into the house. I leave it there in 90°weather and 40° weather. Does not get all yucky like some hand cleaner.
JSNH
I really like the gojo. Is not flamable, it does not smell bad, and it comes out of your hair. I run a manual circular mill and I am showered with sawdust and pine pitch. My arm hairs are matted with the pitch by the end of the day. I find at the end of the day the gojo pulls all the pitch out.
cutterboy
Several years while I was sawing white pine an old gent stopped to watch. He told me to wash my clothes in hot water just as soon as I got home. He said "don't let them sit over night or the pitch will set and you'll never get it out". I've done what he said and I never have a problem with my clothes. However, hands and arms are a different story. Maybe I should try some of that gojo stuff.
To underestimate old men and old machines is the folly of youth. Frank C.
ohsoloco
Wouldn't want to use it on my clothes, but cooking oil or mineral oil will dissolve it from your skin.  I didn't believe it so I tried some mineral oil on my hands.  Takes a little rubbing, but will get it off.
Al_Smith
The hand cleaner trick using Go-Jo or a like product I first found 20 plus years ago from "hints from Heloise".Actually hand cleaner works good for a lot of things.
anchorhd
 will the thinner bother the powder coating?
Barney II
Good question on the powder coating, don't have anything new enough to have been powder coated.  Have to try that go jo stuff sounds pretty good.
Ya never know
Woodmizer  1985 lt30
anchorhd
I have it in the garage and basement.
Works good or us on poison ivy.
woodweasel
what kind of solution are you using on your blade to keep it from building up?
orion388
I've been using water/pine-sol and a splash of Dawn soap... Seems to work great for me ..
LT35HD, Kubota L4330, Stihl 361, 026, Massey Fersuson 55, Ventrac, Grasshopper, Small dumptruck and a huge yearning for knowledge from this forum.
lowpolyjoe
Great thread.  I get covered in sap from time to time and wondered about a good method to cleanup
Thanks guys.
Cguignard
I was sawing lots of pine this spring, one thing that I found hat works was to apply silicone spray to my work gloves and mill handles, no pitch build up.
