Calipers vs D-tape
Started by wmrussel, July 03, 2013, 06:26:23 PM
wmrussel
I'm interested to see if there is a region of the nation which prefers one to the other.
My name is William, but people call me Pete.  Long story......
Ron Wenrich
D tape.  Fits in a pocket or pouch, and I feel its a more accurate measurement.  You can throw a bias by using a biltmore stick or a caliper.
chevytaHOE5674
Ditto to what Ron said. Calipers get big and awkward to carry around all day, especially a pair that can measure large trees.
celliott
I prefer a D tape myself, the self retracting ones with the nail are real handy on big trees.
With that being said, the summer cruising job I'm going to be starting, the company specifies we use calipers.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
ashes
D-tape
I would be in bad shape if I had to carry calipers big enough to measure some of the trees around here. In the 14-16 year old stands we have had to cruise though the calipers could be handy.
Ron brings up a good point about the bias. I hadn't thought about that but trees aren't that round a lot of the time. In fact I wonder sometimes about the limiting distance tables. Say I determine a tree out from a prism or relascope, but its dbh is large enough given the limiting distance. Cases like that are almost always within the allowable tolerance, but I wonder what the appropriate call would be. Strict limiting distance or how the plot is viewed from plot center. I guess I should ask :D
Quote from: celliott on July 03, 2013, 10:47:36 PM
The digital calipers furnished ??   ;D
Hagöf Digitech Professional Caliper
D-tape.  My favorite set-up is a 75' loggers tape where one side is in tenths of feet and the other side of the tape is a diameter tape.  Like Celliott said, the retracting feature is nice.
Ron Scott
~Ron
enigmaT120
Quote from: WDH on July 04, 2013, 07:26:16 AM
I need to get one of those, like a Spenser.  Right now I use a Biltmore stick, but I'm not a pro cruiser so I'm just measuring my own trees.
Ed Miller
Falls City, Or
pappy19
I voted D-Tape but.... if the majority of the timber is 16" or less, calipers or a stick will do fine. Larger timber is much more prone to be off with calipers. Equally important is height measurements, so what is everyone using now?  Seems to me one could use a good range finder for distance and be alot more accurate on tree heights. Thoughts?
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
petefrom bearswamp
Trees that aren't perfectly round in MHO aren't an issue unless we are doing very accurate scientific measurements.
My timber cruising and timber marking days have been over for quite a while now, but any volumes that i offered for sale on competitive bid were estimates only.
The differences?  IMO again were in height estimates as I measured dbh on the thick and thin sides  for diameter...
As my old boss at the NYS dec many years ago said.
It doesn't matter whether you are over or under in volume estimate as long as you are consistent.
I used a cruising stick and occasionally a d tape sticking a few trees for height (log length) in the AM and then estimating thereafter.
Did however use a set of calipers in 1962- 63 measuring NS in plantations.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
wmrussel
My work is checked, so a d-tape is a must for consistency between check cruisers and cruisers.  For height measurements, I use a laser hypsometer.  Up until 2011 I used a clinometer (electronic or regular) and loggers tape to pull the distance.  I generally shoot a height on every plot.  Some exceptions apply, of course.
enigmaT120
I tried to use a clinometer for tree height, but my eyes don't both focus on the same object.  It's like lazy eye or something.  Maybe if I played with one long enough I could use it, for example if I tried moving my head a little so my right eye could look through the clinometer, then over to see the tree top.
Ed Miller
Falls City, Or
wmrussel
Quote from: enigmaT120 on July 09, 2013, 12:34:12 PM
I'd say a digital clinometer might solve that problem.  I think they're about $200 now.  They've gotten fancy.
enigmaT120
I actually found an ap for my Android tablet that measures the angle the tablet is tilted at...  but I haven't played with it to actually measure tree height.  I still need to measure the distance to the tree and set that up.  The ap does the trig.
Ed Miller
Falls City, Or
pappy19
Quote from: enigmaT120 on July 11, 2013, 01:34:53 PM
What is the name of that app?
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
clearcut
There are a number of clinometer and height measurement app on the Google Play store. Search for "clinometer" or "measure height". Both are names of apps and included in descriptions of other apps. Some display the angle of the device only. Others use the phone's camera to sight the top, sight the bottom, and calculate the angle.
I had good luck with an Android app named GeoCam (Free and Pro versions available).  I have also used Theodolite (free and paid versions available) on iOS. Both have a bit of a learning curve.
Carbon sequestered upon request.
enigmaT120
It says "Baumhoehenmesser."  It looks like it's in German.  That could be a problem for me.  What the heck is Winkel?  Ah, angle.  It has English instructions.
Ed Miller
Falls City, Or
hackberry jake
Quote from: enigmaT120 on July 12, 2013, 12:25:16 PM
Now you know how the rest of us feel when you use words like "clinometer".
enigmaT120
That was good.  But wmrussel used the word before me.
Ed Miller
Falls City, Or
At least he did not mention a Haga Altimeter  :-\.
hackberry jake
someone did mention a "laser hypsometer". I remember seeing one of those in star wars. I try to use my flux capasitor for diameter and my warp drive for tree height. just don't throw the diameteric densinominomator in the box with the algebraic nucloid and you'll be alright
The only hypsometer that I used had a ball of string in it, not a laser.  But then again, I am in the South and not as advanced as the Northern Types on here  :).
hackberry jake
Not as advanced? I imagin meeting you and you saying "could you please oblige my will and transfer to my filanges one hexagonal torque multiplying device of the denominational value 5,625 ten thousands of one imperial unit" instead of saying "hey, toss me the 9/16". And probably in a british accent as well. Dont know why  ;D
giant splinter
I prefer the D-tape, the 75 foot case with the 66 foot refill is a nice combo and it rolls up fast
roll with it
