Field mice
Started by John Woodworth, June 25, 2013, 01:16:27 AM
John Woodworth
Had a good one on my VW mtr. off my mill, I haven't run it for a while and brought the mtr. home to check things out as I will be sawing shortly, anyhow after changing the points in the mag and a ganeral tune up it started up fine however  the oil temperature started coming up, I had pulled the covers last time I ran it so I assumed everything was clean, I pulled the covers again to find that last winter the field mice had got in through the blower side and built a nest under the front bank, I cleaned it all out and fired it up again to have a serious oil leak, the pushrod tubes were all eaten through. I got a set of the adjustable pushrod tubes as I didn't want to pull the head, these tubes have a O-ring seal and double jam nut for adjustment and are known to leak at the O-ring so I put silicone sealer arounr the tube end below the O-ring and it's leak free. Guess I'll have to block off the blower or else set mice traps from now on.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
Satamax
Ahhh, that's where the word pestering comes from ;D
John,
I could box up some snakes from down here and ship them to you via USPS flat rate box.  Shipping would only be $17  :D.
John Woodworth
Thanks WDH but I don't think the local two legged snakes living here woulk like the competetion.
Tough break John.  I think that I would be blocking, trapping, and poisoning.  I hates mice.   :-\
hamish
I hate cats but keep two of them around for rodent duty.  Feeding them near the mill keeps there daily/nightly patrol in the mill sector, unfortunately they bring all there kills back to the house.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
drobertson
This is my ratter around the mill, Dixie has saved many of issues with her hunting tactics, 8)  david
POSTON WIDEHEAD
She probably listening to that song, "WHO LET THE DOGS OUT".
Chuck White
I had them critters eat the gas line.  I guess they needed more room for thier nest.
hackberry jake
Quote from: POSTONLT40HD on June 25, 2013, 06:39:40 PM
:D
Aint nothin but a hound dog... millin all the time
redbeard
I have owls and one perches on my mill control box. Hopefully the game camera will get a photo. So there will be proof. They also hang out in my drying shed.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
drobertson
I just wish I had a shot of every kill she has made, it would blow you guys away, although she is getting old now, but still on the hunt, even today,   david
They make repellant for Mickey and his buddies,they say peppermint smell will keep them away.My first circular mill was off in the woods by a stream,had no rodent problem a feral mother cat had a litter in the engine house.Kept noticing little tracks all over the sawdust pile,they would scatter when the diesel would start but come home to a warm house. Frank C.
terrifictimbersllc
Sprinkle red pepper everywhere occasionally and they'll stay away
