Looking t make some taxidermy deer head panels from a pine log
Started by rasorbackQ, June 20, 2013, 02:45:41 PM
rasorbackQ
 Has anyone on here ever sawed a big log on an angle to form a flat panel oval shaped with bark all the way around?
If so how did you support the log to cut it and at what angle did you cut?
Thanks for reading, Steven
drobertson
Yes, and I set the log between the rails, about 45 degrees, used two 4x6's on each side to help support while clamping the stock, the stock was 4' long.  david
wetdog
Quote from: drobertson on June 20, 2013, 02:56:35 PM
How did you keep the bark from falling off after drying?
drobertson
I cut some for my daughters wedding, and sealed it with a clear coat from a can, still on after a year, the walnut I did for a customer, he used a high dollar mix, not sure what it was, but he came by two days ago wanting more, and they are for plaques of the same nature,  he was very pleased in the finished product.  I would say, displace and replace the sap.  It should work,  david
scully
I bleed orange  .
drobertson
Hey Scully, this is true with walnut,  the white oak I used for my daughters sign in board however is still holding the bark!  I still can hardly believe it,  and it is a year and a half old,  I know there are treatments for this , just don't know off hand the name,   david
The best way to retain the bark is to fell the tree in the winter when the tree is dormant and not growing.
rasorbackQ
 Thanks Drobertson .   Think the way to keep the bark on is  drying very slowly.
POSTON WIDEHEAD
Once you drop your tree in the winter......never let the bark see rain, or hot sunshine again.
I've done this a lot. Drastic change in humidity and temperature will cause the bark to release.
Seaman
Next time you saw a nice walnut with a big limb, leave a foot or so of limb, point it up on saw, and cut.
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
