setting blade guides
Started by fivedogs, June 13, 2013, 07:49:37 PM
fivedogs
installed  new blade  guides   logs tampering  down as i get past  8 ft  checked the deck and the head of the mill  seems level
how do i check my guides are they too tight or unlevel  or pushing the blade down
throwing off the set ?
littlle  help would be appreciated
Trying to follow along. Assume "tampering" means "tapering".
Can't imagine the guides pushing the blade down.
What mill?
Ga Mtn Man
Your guide rollers must hold the blade parallel to the saw deck.  You need a blade alignment tool to do the job right.
This one is from Cook's or you can make your own like I did.  Woodmizer also sells one.  A torpedo level will get you by, assuming your mill is perfectly level.
fivedogs
drobertson
fivedogs, not sure about your mill set up, but, if the cut is tapering down, threw the cut , the alignment is off, simple as that.  And if it takes 8' to show up it's not that bad, imo, find a tool, or way to correct the alignment, this should fix your issue.    david
Fivedogs. has the mill just done this once or with multiple bands.I would try a new band if she taperes then check alignment as mentioned. Frank C.
never finished
  I'm not sure if the guides on the newer mills are the same as on my Oscar 36. Setting the guides tighter than  the book said helped on a few issues. It is very important to have the frame level cross ways the full length of the frame also.
Happycamper
I have had my mill 3 months and use it occasionally. I checked my blade guides the other day and found one to be original size and the other 3/32nds smaller than original so it was not putting the correct amount of pressure on the blade. Bearings in both guides were ok.
                                  Jim
Wether you think you can or you can't you're right
Happycamper
Another thought, hook angle and blade set can also do this, increase either or both a little bit 2 or 3 thou. and that might cure the problem. I have found blade set was the answer to many problems I was having. A sharp or dull blade will cut correctly with proper set but neither will cut right if the set is off.
I set and sharpen my blades by hand not with auto sharpener setter.
                                       Jim
Piston
Happycamper,
Did you take that picture in your avatar photo?  That's a good shot!
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
Happycamper
Piston,
  Yes, I was hiking in Yoho Nat. Park when I ran into a mother and three cubs. Another time I ran into a grizzly and two cubs but was too scared to click the camera, That was in the Kootenays.
                                       Jim
fivedogs
Thanks  for all the advice  i used a  small level  got them adjusted  real well
put a brand new blade on and the wood cut  straight as can be  loving it
thanks again for  taking the time to help me out
                          fivedogs
