Timberking's remote throttle controller
Started by red pine, June 08, 2013, 09:52:21 AM
red pine
Just installed the remote deck switched controller and love it. (Removed my lawn mower controller I had devised). Expect to save fuel at $1.27 per liter. (that converts to $4.81 per U.S. gal.) 8)
ladylake
Good going , every mill with a stationary command post needs a remote throttle.  I'd never mill without one.   Steve
xlogger
I put one on my TK with help from Steve. One of the best things I've done with it. Ricky
ladylake
 It's good to see TK was listening as remote throttle comes standard now on the TK 2000.  Steve
Ga Mtn Man
Good for you Red Pine.  Probably the most useful mod you can do.  Here's your next project ;D:
ladylake
Paul
Looks like you've been busy  Steve
Ga Mtn Man
red pine
Ga Mtn Man
Where did you get that throttle switch? Does it actually work as per the written functions? i.e. off, run, etc. I assume it also controls engine speed. By the way I placed my switch in an identical location rather than at bottom of the red electronic box recommended by TK.
Did you use a similiar control/actuator for the choke?
Will_Johnson
Here's to customer feed-back and ingenuity!
Note that as mentioned remote throttle now comes standard with the standard swing command post on all TK 2000 mills. Remote choke and remote start are also available options now.
Nomad
Quote from: Will_Johnson on June 10, 2013, 09:40:54 AM
     I may not run a TK, but I REALLY like seeing a manufacturer give kudos to customers for thinking "outside the box." 8)
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Ga Mtn Man
Quote from: red pine on June 10, 2013, 08:52:30 AM
Ga Mtn Man
That's just the key switch taken off the engine.  Yes, OFF-RUN-START work as indicated.    The throttle switch is mounted on the left side of the setworks box.  I used a solenoid for the choke.  You can see it in the pic in "Essential TK Mods" thread.
Ga Mtn Man
Here's to manufacturers listening to their customers! smiley_operator
